> Low whine at lower RPM
post Sep 17, 2008 - 10:54 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
For about a week or two I've had this low whine that I can hear when I start it up and when I'm driving anywhere below 2k RPM. I've looked under the hood while it's running, and I can only guess that it's the alternator. I did have my timing belt/water pump done in October, and I've heard they tend to whine, so could it just be that?
-Matt
Replies (1 - 11)
post Sep 17, 2008 - 3:19 PM
D-Man
Joined Jan 18, '08
From Houston
belts? As they wear out, they tend to make some noise... IDK what kind of whine is it?
Damn D-Man - most impressive.
post Sep 17, 2008 - 3:27 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (D-Man @ Sep 17, 2008 - 3:19 PM) *
I really don't know how to describe a whine other then it being a whine, lol.
My belts all appear to be fine. Maybe it's my lower belt that I can't look at. I'll check it out soon.
-Matt
post Sep 17, 2008 - 6:27 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Yeah I just looked at my belts and they're both in great shape.
post Sep 17, 2008 - 7:19 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
quick way to see if its the alternator....unplug the connector that goes to the back of it. if the whining stops its probably the alt whining a little. dont worry about it till it stops working.
otherwise the intake can whine a little as well as the trans, more so in 1st gear for an automatic.
post Sep 17, 2008 - 8:20 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (Bitter @ Sep 17, 2008 - 7:19 PM) *
Cool deal, I'll try the alternator trick. And it's a manual, but I doubt it's my intake since it's stock.
-Matt
post Sep 17, 2008 - 9:53 PM
azian_advanced
Joined Apr 18, '05
From Calgary
also double check if the tension on the belts are tight..
cold/loose/worn belts will tend to make that whining sound after/during start up especially during acceleration in the low rpms.
post Sep 17, 2008 - 9:58 PM
97celiman
Joined May 22, '08
From dallas texas
hey ive always had this whistling sound when accelerating in my car...doesnt seem to be anything unusual and nothing has come of it yet i think its just a natural noise the car makes...we could be talking about something totally different...saturday ehh?
post Sep 17, 2008 - 10:02 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (97celiman @ Sep 17, 2008 - 9:58 PM) *
Do you have a stock or aftermarket intake? An upgraded intake could make a whistling sound at higher RPM.
post Sep 18, 2008 - 12:55 PM
Project7afte
Joined Mar 18, '08
From Staten Island, NY
Mine whistles a little too, but I know it's because of the intake. The reason is that the box that inhibits the sound of the air rushing through the filter isn't there anymore.
post Sep 24, 2008 - 9:28 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
It's prob. the Harmonic Balancer. Mines making the same whine too but I think its either coming from the timing belt being to tight or the Harmonic balancer is bad because its got a lot of chips on making it wobble maybe.
post Sep 30, 2008 - 9:28 PM
relyks95gt
Joined Sep 29, '08
From miami
mines doesa to butlike when iv been drving it for a while and ill open the door to get off(engine still on) and its preety noticeable and loud.ill turn off the engine and start it back up and it still does it but when i let it sit for a while it dosnt do it till i run it for like another 10min. i just thought it was an exhaust leak
-RELYKS
Lo-Fi Version Time is now: March 21st, 2026 - 2:49 AM
