> gauge cluster
post Sep 23, 2008 - 1:48 PM
trex6g
Joined Aug 4, '08
From tennessee
my tech,speed,and temp,gas gauge will not light up,but all of the other lights on the cluster are working,check the fuse,replaced the bulbs,is there and relay somwhere that might need replacing? kindasad.gif
trex6g
This post has been edited by trex6g: Sep 23, 2008 - 1:51 PM
post Sep 23, 2008 - 1:50 PM
DEATH
Joined Dec 19, '07
From tx
Is the dimmer switch hooked up and turned all the way clockwise? The lights will not function without the dimmer hooked up.
This post has been edited by DEATH: Sep 23, 2008 - 1:50 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Sep 23, 2008 - 1:52 PM
trex6g
Joined Aug 4, '08
From tennessee
yes,could that be bad?
post Sep 23, 2008 - 1:54 PM
DEATH
Joined Dec 19, '07
From tx
everything can go bad. My suggestion is to find a friend nearby who will let you borrow his for a minute so you can eliminate that as a potential problem. After that take a multimeter and make sure it is getting power in and out of the dimmer.
EXT: WRC/TRD/404
post Sep 23, 2008 - 2:51 PM
Redline08
Joined Feb 23, '07
From Albany, NY
climate control lights work?
post Sep 23, 2008 - 3:26 PM
DEATH
Joined Dec 19, '07
From tx
Good point. Are the only problem lights in the gauge cluster or are there problems elsewhere in the dash/center console?
EXT: WRC/TRD/404
post Sep 24, 2008 - 12:48 AM
trex6g
Joined Aug 4, '08
From tennessee
just checked and the climate control. the little green light will come on when i push on the ac or any of the other buttons on it,but as for the hold control no lights
This post has been edited by trex6g: Sep 24, 2008 - 12:53 AM
post Sep 24, 2008 - 12:49 AM
CelicaST_CALI
Joined Feb 28, '07
From Banland
i dont think it would be a dimmer then if it lights up when u push it...
BANNED. for life, you moron.
post Sep 24, 2008 - 1:03 AM
trex6g
Joined Aug 4, '08
From tennessee
QUOTE (CelicaST_CALI @ Sep 24, 2008 - 12:49 AM) *
only the green lights on the buttons will come on .the unit itself not lighting up.shouldnt it light up
post Sep 24, 2008 - 11:31 AM
DEATH
Joined Dec 19, '07
From tx
Blown fuse most likely.
remember that sometimes they don't look blown even when they are - replace it anyway to eliminate the possibility.
This post has been edited by DEATH: Sep 24, 2008 - 11:32 AM
EXT: WRC/TRD/404
post Sep 24, 2008 - 1:04 PM
trex6g
Joined Aug 4, '08
From tennessee
checked for voltage on the dimmer,and i got voltage.also check the gauge cluster and ohm each of the lights and they ohm out.like to say thanks to everyone that is helping me with this.
trex6g
post Sep 24, 2008 - 1:40 PM
DEATH
Joined Dec 19, '07
From tx
Damn - stumping all the usual suspects - guess we'll have to dig a bit deeper. Let me do some thinking, in the meantime maybe someone else might have some info.
EXT: WRC/TRD/404
post Sep 25, 2008 - 11:46 AM
trex6g
Joined Aug 4, '08
From tennessee
replaced the fuse and it work.you was right ,fuse didnt look blown.
post Sep 25, 2008 - 11:58 AM
DEATH
Joined Dec 19, '07
From tx
EXT: WRC/TRD/404
post Sep 25, 2008 - 1:59 PM
trex6g
Joined Aug 4, '08
From tennessee
yes the fuse wasnt broker nowhere in it.thanks for everyones help
trex6g
Lo-Fi Version Time is now: September 11th, 2026 - 5:17 PM
