> need help finding the problem
post Sep 24, 2008 - 1:22 PM
GoToSleep
Joined Feb 19, '08
From Elk Grove/South Sac
hey 6gc i need help bad i thought it was my axle but i got under the car today and looked and the passenger and driver side axles were fine but here is the problem when i make soft right turns or right turns in general and even driving straight well it makes a clunking noise/grinding frown.gif and you can feels like its vibrating also on the right side only is it the wheel bearings or what can it be im used to hondas and this is my first toyota so im kinda lost different layouts frown.gif
Jayson
post Sep 24, 2008 - 7:38 PM
GoToSleep
Joined Feb 19, '08
thanks for the help guys but i found the problem the axle nut was lose so it grind and messed up the hub and spindle and now i have to replace it so just a heads up for you 6g members make sure everything is torqued down and tight
Jayson
Lo-Fi Version Time is now: May 25th, 2026 - 11:11 PM
