> Need URGENT axle removal help!!!
post Sep 27, 2008 - 7:03 PM
95celgt
Joined Oct 5, '03
From South TX.
Hey guys im in the middle of swapping out my driverside axle but the inner hub wont come out!!
I first tried pulling the thing out and it popped off the boot, so i rented a pitman arm puller, wedged it in and hit with hammer to no avail!!
so how do i get this dang thing out?!?!?
post Sep 27, 2008 - 8:21 PM
holy crap, that is messed up.
Ok there is no real science. the drivers axle will require some technique to it. with a big prybar, push upwards and then with a mallet give a steady blow, there is a pin holding it siside the transmission. the passenger side needs 6 bolts removed.
put the prybar between the dust shield and tranny, look for a little bump thats where it goes. Its about learning. That thing you rented wont help much tough.
good luck.... i dont have pics atm. its hard, the first time i tried for six hours. then 1 hour. its just a pain.
found this not a celi, but get the idea.
post Sep 27, 2008 - 8:51 PM
95celgt
Joined Oct 5, '03
From South TX.
the thing is that this thing is rounded, and if i try that (hold and hammer out) it just slips out frown.gif
i gave up for today ( been trying since 10 am) so ill try again tommorow
post Sep 27, 2008 - 9:19 PM
QUOTE (95celgt @ Sep 27, 2008 - 9:51 PM) *
i know dude, same thing, but if you hold it steady it it less likely to slip out, try your best. Its doable. I was in your shoes the first time.
put the bar, push up steady and wham. go rest, tomorrow new day. are you on jacks. It helps it the car is raised a little high, you need all space you need.
post Sep 27, 2008 - 9:39 PM
95celgt
Joined Oct 5, '03
From South TX.
yep its on jacks, im gonna buy a pry bar tommorow hopefully,.....today i broke 1 Breaker bar, 1 3/8ths ratchet, broke a WELDED 1/2in ratchet (welds broke on the mechanism where it was modified to not ratchet anymore), rented the puller, and broke some other tools because the passenger nut is seized on to the hub, all with my 4 foot cheater pipe!! lol, i will update in the mornin smile.gif
post Sep 28, 2008 - 2:51 AM
azian_advanced
Joined Apr 18, '05
From Calgary
looks like you're doing it right.. just need a bit more instant Impact to snap it from it's locked position..
post Sep 28, 2008 - 9:11 AM
QUOTE (azian_advanced @ Sep 28, 2008 - 3:51 AM) *
exactly!!
post Sep 28, 2008 - 11:35 PM
95celgt
Joined Oct 5, '03
From South TX.
OK so i bought a better pry bar, positioned it at the top, placed the old L shape tire iron on the bottom, one coordinated foot and hand move and BAM it shot straight at me!!!!! laugh.gif
so i got the new axle in, put everything back together, and when i was tightening the axle nut on the hub something popped real loud!...should i be worried??
i dont see any visible dammage but when i turn all the way to the right and drive while turning it makes a scraping sound kindasad.gif
post Sep 29, 2008 - 2:21 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I don't know the first thing about this stuff but that real loud pop... could it be the axle popping out of its, uh, thingie? I wouldn't drive it at all until you get that figured out, so you don't risk any damage/further damage.
post Sep 29, 2008 - 2:34 PM
JDM_Factory
Joined Mar 27, '08
From Fort Worth, TX
You should be fine. Most of the time I use a hammer and a crow bar to pop it out.
make sure you torque it correctly, too tight will crush bearings.
post Sep 29, 2008 - 4:51 PM
QUOTE (JDM_Factory @ Sep 29, 2008 - 3:34 PM) *
what?
the axle nut gets like 160+ ft lbs of torque.
your not crushing bearings, or anything else for that matter.
lol
OP, make sure the axle didnt pop back out.
Lo-Fi Version Time is now: January 25th, 2026 - 10:48 AM
