Sep 30, 2008 - 2:25 AM
Enthusiast ![]() ![]() Joined Jan 2, '08 From Scotland Currently Offline Reputation: 3 (100%) |
Want to pick your collective thoughts here. Since the V6 went in (the front/rear gearbox mounts are with polyurethane), I get loads of wheel hop from the car.
Looking at possibly fitting a torque damper(s). Also, will any of the GT4 mounts fit? I was thinking of utilising those & poly filling them as well. Already sorted out a LSD gearbox, thinking of fitting a whiteline front anti rollbar too. Any other thoughts/suggestions welcome. -------------------- Regards
frisp HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6 To be done.... Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads |
Sep 30, 2008 - 8:37 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Actually if you switch to the E153 tranny [You may already be IDK] then the mount you would use for the rear is the GT4 mount. The front is the same on everything except the 1.8l IIRC
-------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Sep 30, 2008 - 9:09 AM
Cheers Death. I can source an ST205 TRD mount for the front easily enough. May go for that & new poly'd rear and fit torque dampers.
Sep 30, 2008 - 9:21 AM
Where will you get that?!? I had those years ago like 4 Celicas ago and they were awesome! Definetly source those if you can and it will end your wheel hop problem [like you said - need the rear poly too]
Sep 30, 2008 - 11:45 AM
Tire pressure & suspension also should be looked into when trying to remedy wheel hop.
Sep 30, 2008 - 4:12 PM
Tyre change on the cards to do. Toyo Proxies, Yoko Parada or Eagle GD3's. Will play with the rebound/compression on the Teins, see if I can't dial it out.
| Lo-Fi Version | Time is now: August 4th, 2026 - 11:21 AM |
