> Clutch issues
post Oct 11, 2008 - 10:58 PM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
Okay, last year my clutch was slipping and eventually left me on a horrible drive. So $850 later, I had it fixed and it felt like driving a new car. Now it is starting to slip again (thank God still under warranty until the 28th of December). The car seems to be leaking oil, and possibly clutch fluid. So no matter how stupid of a question this may sound, do you think the leak is causing this? It is only 1st and 2nd gear (2nd not so much as 1st when I push it a lil and if I drive it really slow, no issues). Or do you think that perhaps the clutch sucks and that warranty needs to be put to good use?
Is there an upgraded clutch I can use that won't bust my pressure plates? Someone please help, this is driving me nuts. If it is a seal, do you know roughly what is "Guesstimated" for repair? Ah man...... I guess just any information could be very well considered. I am aware with a vehicle, there are many things that can be wrong and without a proper diagnostic, it is hard to determine the absolute problem. I am just learning all this stuff in school, but with basic classes. Anyways, any help is appreciated. Thank you ahead of time.
post Oct 16, 2008 - 1:49 PM
Random_Stranger
Joined Mar 20, '07
Ok, so can I put a Stage 2 clutch on my stock GT? I am just going to ask that now. Also, I heard the OEM clutch sucks for our cars. How valid is this information?
post Oct 16, 2008 - 1:57 PM
Etak28
Joined Sep 2, '06
From Mechanicsburg, PA
QUOTE (Random_Stranger @ Oct 16, 2008 - 1:49 PM) *
Yea you can put a Stage 2 in your stock GT but if you plan on going turbo in the really near future i would recommend going higher stage. About the OEM one, idk if thats true or not, Im on my second OEM and im going turbo now and nothing wrong yet... Guess its luck of the draw.
Believe most of this is correct, anyone can correct me if i'm wrong
'99 Celica GT - White
Etak28
post Oct 16, 2008 - 2:05 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
QUOTE (Random_Stranger @ Oct 16, 2008 - 2:49 PM) *
stage 2 is fine you can put what ever clutch you want in, but it really depends on where you get you oem from toyota or a retail store like napa or autozone etc. when i had my 5sfte my oem clutch lasted me a while but once i started to beating on it, it started slipping..got another oem one from toyota and it lasted me a while..i guess it really depends on how you drive..
post Oct 16, 2008 - 3:58 PM
Random_Stranger
Joined Mar 20, '07
QUOTE (RUNNIN-LOW @ Oct 16, 2008 - 12:05 PM) *
Thanks. So what say you about my clutch? I know it is hard to say. I had it done in December of 07' and I have a year warranty. It was fine up until last month, started to slip a bit, figured it was my fault, and now it is a lil worse. I know I can last like this until January, because if I do not accelerate hard, it does not slip. But I kinda do a lil bit. Then again, friends say I might have a tranny leak. Now if in fact it is transmission fluid (I am guessing), I would imagine the leakage to be thick, in which it is not. Just looks like I have an oil leak.
I think I should just take it in again and tell the guy it is slipping again and have him fix it. What do you guys think? Sound good? Ya? I doubt he ordered from Toyota. He has a local business.
This post has been edited by Random_Stranger: Oct 16, 2008 - 3:58 PM
post Oct 16, 2008 - 7:59 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
Do you know what type of clutch the mechanic used? I read through your post but I might have missed it. My car was purchased with the clutch shot. As far as OEM clutches go, I don't know what the heck the guy before me did, but @ 188k that clutch came out in pieces- and not one or two. I've since had the ACT stage 2 and thats been for about 4 years now, and .... 50k miles later, it grabs like day 1.
My F/S Thread!
Ferdi says (11:29)
post Oct 17, 2008 - 1:46 PM
Random_Stranger
Joined Mar 20, '07
QUOTE (samir0189 @ Oct 16, 2008 - 5:59 PM) *
Honestly I have no idea what type he used. It is under warranty though, so I might make a deal with him and purchase the part if they do the labor. I think it is a fair deal, because if not and he puts cheap stuff in there again, I can keep burning through it and it will cost him more.
Lo-Fi Version Time is now: September 15th, 2026 - 2:28 AM
