Oct 18, 2008 - 1:35 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
If they are on does that make the car jack unusable?, pretty simple question that i dont know the answer to
Thank you This post has been edited by whatthe: Oct 18, 2008 - 1:35 AM -------------------- |
Oct 18, 2008 - 9:33 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
I cant say 100% mostly cause I dont have side skirts, but Id have to say no. I couldnt see them saying "Here you go, dealer option sideskirts for your car, dosent that look nice. Oh by the way, you cant use the jack to change a tire because the skirts will make the car tip over."
Oct 18, 2008 - 10:28 AM
Enthusiast ![]() Joined Jan 15, '08 From Knoxville, TN Currently Offline Reputation: 2 (100%) |
If you use the factory car jack that sits under the pinch welds behind the side skirts you will crack the skirts that is if you can even fit the jack under the car. Although what i have done in the past is ride the car on wooden blocks just under the tires and use a standard floor jack. That works great for me and you still get to change 2 tires at a time. Also if the ss are factory you might have enough room to use the stock car jack if you jack up the car in the middle of the sides where the side skirt curves up i do believe you have enough room. I wish i could be more help but i had the z glide skirts and my car sat about 4'' off the ground (give or take). Good luck!
Oct 18, 2008 - 10:29 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
The backs of the skirts are hollow, the jack sits behind them.
Oct 19, 2008 - 12:30 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 12, '06 From Fresno CA Currently Offline Reputation: 1 (100%) |
i have side skirts and tein springs and the jack can't go under,so what i do i driver over a little wooden board.gives me enough space to jack up the car
Oct 20, 2008 - 9:55 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
i guarantee 100% that the vert skirts will never interfere with jacking up the car
Otherwise, get one of the 10-20 dollar canister jacks at your local auto shop. They shouldn't mess with the skirts as they'd go around them. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Oct 20, 2008 - 2:21 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
With boomer sideskirts lowered with Tien Springs.. Def can't from side.. not even with the low style jacks..
so I have to start from back.. then get side.. then go to front.. LOL -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Oct 22, 2008 - 3:36 PM
OEM skirts does not render the jack areas useless. The skirt looks lower from the outside but towards the jack sections they level back out. You still can use the scissor jacks.
| Lo-Fi Version | Time is now: August 27th, 2026 - 8:29 AM |
