Oct 22, 2008 - 3:56 AM
Enthusiast ![]() ![]() ![]() Joined Sep 23, '08 From Hawaii Currently Offline Reputation: 10 (100%) |
i just got a new pair of 6.5" kicker components ($50
on a side note is this normal: i ran my engine with radio/lights/ac off and disconnected the battery. ran fine but when i turned on the headlights the car shut off. should the alternator be able to handle w/ headlights and accessories? or by turning on lights i created a surge? should i try running the engine w/ the headlights/acc on, then disconnect? this ties into overwhelming the electricals...i still dont have a volt meter my setup: jvc pdr30 hu 500w alpine amp 2 10" alpine type e's stock speakers 4 neons w/ switch going in this week big three upgrade(4gauge) so basicly, how much more can my electricals handle? dont want to replace alternator/add capacitor/get a bigger or add a battery. based on my setup, and average alternator capability these are the choices of things i would like to hear: 1.install components and dont max out volume, get an amp later(it should be fine for now) 2.get a cheap amp because your electricals can handle the added draw 3.what the hell you doing, your system is maxed. 4.your alternator needs replacing any help is appreciated guys. This post has been edited by captb: Oct 22, 2008 - 3:57 AM |
Oct 22, 2008 - 6:45 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Ok, first you need a multimeter if you're going to be doing electrical work on your car... Second, the will be fine without an amp for the time being, but if you ever want the full range out of your speakers you need an amp. Get your electrical system tested for free at autozone/advance auto. They test the charging system and battery.
Oct 22, 2008 - 2:35 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 21, '08 From Naples, FL Currently Offline Reputation: 0 (0%) |
20 out of 50? That's nothing...bearing in mind that some of my downloaded songs have volume differences, I've had it at 52/62 before.
Oct 22, 2008 - 4:23 PM
![]() Enthusiast ![]() ![]() ![]() Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) |
You stereo should be fine. Install them without an amp and enjoy. I assume they have crossovers correct? If they do, they will work essentially like 1 speaker, but sound a lot cleaner.
I have been running a set of 5 1/4 components for about 5 years now and they sound as good as ever. Never had them amped either. -------------------- |
Oct 22, 2008 - 7:52 PM
Enthusiast ![]() Joined Oct 2, '08 From New Zealand Currently Offline Reputation: 0 (0%) |
My 0.02
I have a 50Watt Head unit running my Front (6.5" 3 way + Tweeters) and Back (6.5" 2 way) and a AMP running the 12" Sub at the back. So Yes you can run the Car Speakes from the Head unit But 10" to 15" Subs will have to be Amped. The Subs have to be Amped due to our hearing range (Hear highs better than Lows) and the amount of Air the 10" to 15"'s push around. -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
![]() ~ signature made by jaws4god ~ Have a look at my thread for updates on my progress. "http://www.6gc.net/forums/index.php?showtopic=63338&hl=0" |
Oct 22, 2008 - 11:27 PM
Enthusiast ![]() Joined Jul 12, '08 From QLD, Australia Currently Offline Reputation: 0 (0%) |
also with the 50watt head unit, remember this is peak power, you need to know the RMS power to tell what quality it is.
Oct 23, 2008 - 12:23 AM
thanks. my hu is 22rms and 45-50max.
Oct 23, 2008 - 5:47 AM
22rms is pretty dam good, my IDA-X100 is only 18, but it can go pretty loud before distorting with my Type-r components
Oct 25, 2008 - 5:29 PM
just stayed up until 4am last night installing the components. only tried them at low volume but from what i can tell they came out as expected. thanks for everyones help.
also i suggest to everyone the big three upgrade. just checked it again yesterday, turning on the lights before i disconnected the negative and apparently my 14yr old alternator can handle the engine, headlights, and my sounds(low volume) on its own. |
| Lo-Fi Version | Time is now: August 28th, 2026 - 3:36 AM |
