Oct 23, 2008 - 10:33 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
I bought a supposed to be "Complete" 5sfe from 6gcelikas and he took forever sending the motor out. And upon receiving it I didnt get some parts. I would not do business with this guy again. I feel as though I almost didnt get my motor it was that shady. Anyways onto the parts!
So far I need: -Complete distributor -Ignition COIL -Plug wires -Coolant neck off the back of the head w/ all sensors -Throttle body with TPS sensor -oil sender unit * located at the front of the head* -ICM (Ignition Control Module) Might need more im still reconstructing it! PS: anyone know if Im going to need to buy a spark coil as well or is that internal in the dizzy?? This post has been edited by celicast3sgte: Oct 24, 2008 - 9:35 AM -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Oct 23, 2008 - 10:44 AM
Enthusiast ![]() ![]() Joined Sep 13, '06 From St. paul, MN Currently Offline Reputation: 10 (100%) |
I may have a coolant neck, I'll go look for it. And yes, the coil is internal.
Oct 23, 2008 - 10:54 AM
oh ok cool, does the neck have all the sensors in it?? pics when you find it please!
Oct 23, 2008 - 11:08 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
I might have the TB with the tps. I know for sure I have the distributor with the internal coil. Its almost brand new.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Oct 23, 2008 - 11:41 AM
Found it. I'll PM you with pics/price later tonight.
Oct 23, 2008 - 12:48 PM
Found it. I'll PM you with pics/price later tonight. awesome man ill keep my eye out! I might have the TB with the tps. I know for sure I have the distributor with the internal coil. Its almost brand new. gimme a price quote shipped for both items if you find it all. and pics as well please! -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
I'll try to get some tonight, but I have class until 9
Oct 23, 2008 - 12:52 PM
oh yes, and to add to it all. i need the oil pressure sender in the head!!
Oct 23, 2008 - 1:44 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) |
oh yes, and to add to it all. i need the oil pressure sender in the head!! I have one $25.00 shipped -------------------- ![]() |
Oct 23, 2008 - 2:21 PM
What was it pulled from and are you sure it works?
20 shipped? -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Oct 23, 2008 - 3:11 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
I have a distributer and cap I can send out for $80 shipped if you would like.
-------------------- Member of Team 5sfTe
Oct 23, 2008 - 4:50 PM
oh this keeps getting better and better...
*adds Ignition Control Module to the list* -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Oct 23, 2008 - 7:15 PM
What was it pulled from and are you sure it works? 20 shipped? Ehh..22 shipped. And yes i know it worked. Came off my 96 cam... I have an entire 5sfe im parting as well. So whatever you dont get from these guys i can supply. This post has been edited by slow_yota: Oct 23, 2008 - 7:20 PM -------------------- ![]() |
Oct 23, 2008 - 8:34 PM
ok lemme double check that I for sure don't have it.
Oct 23, 2008 - 10:39 PM
Enthusiast ![]() ![]() ![]() Joined Jan 16, '07 From covington, KY Currently Offline Reputation: 9 (77%) |
the coil is NOT internal
if you look at the top right corner, about 4in away from the LED light the silver box is your Ing. Mod. and bolted to it is your coil ![]() |
Oct 23, 2008 - 11:16 PM
its because you have obdII. Us OBDI are internal
Oct 23, 2008 - 11:19 PM
What he said...=]
This post has been edited by slow_yota: Oct 23, 2008 - 11:22 PM -------------------- ![]() |
Oct 24, 2008 - 5:38 AM
its because you have obdII. Us OBDI are internal for 94-5 only the federal spec cars had an internal coil. california emmision cars got the external coil, and all 96+ have the external, IIRC. -------------------- Former Team 5SFTE pro member ;)
Oct 24, 2008 - 9:17 AM
Enthusiast ![]() Joined Oct 30, '05 From MICHIGAN Currently Offline Reputation: 11 (76%) |
I bought a supposed to be "Complete" 5sfe from 6gcelikas and he took forever sending the motor out. And upon receiving it I didnt get some parts. I would not do business with this guy again. I feel as though I almost didnt get my motor it was that shady. Anyways onto the parts! So far I need: -Complete distributor -Coolant neck off the back of the head w/ all sensors -Throttle body with TPS sensor -oil sender unit * located at the front of the head* -ICM (Ignition Control Module) Might need more im still reconstructing it! PS: anyone know if Im going to need to buy a spark coil as well or is that internal in the dizzy?? [size="6"][/size]My response to your claim >>>>>>>>>>>>>. Where do we agree to distributor, coolant neck with sensors, T/body, oil sender unit, ICM. Can you copy the PMS that I send? These are separate parts and I will have to charge you for it. Complete engine means head, intake, long block, crank, oil pan. When we communicated you never mention this parts and now you claim that I short handed you. You never asked for these parts and now you claim that I did not send them |
Oct 24, 2008 - 9:20 AM
| Lo-Fi Version | Time is now: August 27th, 2026 - 12:30 PM |
