Oct 25, 2008 - 5:44 PM
Enthusiast Joined Oct 16, '08 From New York Currently Offline Reputation: 0 (0%) |
I'm trying to get my car on the road again. I have already installed the turbo, exhaust, A/F ratio and boost gauge, helicore ignition wires, oil line, FM inthercoolerand piping, and new plugs gapped to .030.
Things to do: 7mge injector-will arrive tomorrow MSD 6 BTM- tach harnes adjuster is on the way 2 Bar Map Sensor! I have been trying to get a 2 bar map sensor installed, but the PN in the sticky is invalid according to the dealership I asked; "2 bar MAP sensor(part# 84420-17030)". I asked about the MAP Sensor for the turbo 93 celicas and he said he cannot look them up without a VIN. I called back a couple of times and had no luck gettin it from the dealership. So I was on another forum that told me the GM 2 bar map sensor would work. It doesnt. My car will go to idle but if you touch the gas at all the car trys to stall. The car ran to the point were I could rev and was only an issue at high rpms or WOT before I had the GM 2 bar MAP sensor. How can I get the correct 2 bar map sensor that my ecu can understand? |
94silverbullet 5sfte map sensor issue Oct 25, 2008 - 5:44 PM
94silverbullet Sooooo tell me that the sticky has the F****ing pa... Oct 25, 2008 - 6:25 PM
presure2 its very easy to find one, if you follow the stick... Oct 25, 2008 - 7:26 PM
94silverbullet okay thanks.
since you seem like the go to guy, I ... Oct 26, 2008 - 12:08 PM
presure2 QUOTE (94silverbullet @ Oct 26, 2008 - 1... Oct 26, 2008 - 1:19 PM
Smaay thats an itiot parts guy you have. just tell them ... Oct 26, 2008 - 1:08 PM
94silverbullet totally agree, the parts guy was mentally handicap... Oct 27, 2008 - 10:42 AM
LewFX "It doesnt. My car will go to idle but if you... Oct 27, 2008 - 11:05 AM
94silverbullet so you think that when the toyota 2 bar map sensor... Oct 27, 2008 - 11:58 AM
Batman722 haha
if you put in a turbo, bigger injectors, a ... Oct 27, 2008 - 12:14 PM
Theshanon dude i donno bout in new york but i would recommen... Oct 28, 2008 - 3:23 PM
94silverbullet I have read just about every post I can find and I... Nov 18, 2008 - 3:21 AM
94silverbullet Basically I need it to run well enough to live for... Nov 18, 2008 - 3:36 AM
presure2 QUOTE (94silverbullet @ Nov 18, 2008 - 3... Nov 18, 2008 - 6:17 AM
94silverbullet okay, I'll make sure the 255lph walbro GSS-342... Nov 18, 2008 - 1:56 PM
presure2 QUOTE (94silverbullet @ Nov 18, 2008 - 1... Nov 18, 2008 - 2:20 PM
94silverbullet I'm using the 440cc supra injectors. those sho... Nov 18, 2008 - 6:59 PM
94silverbullet so trying to find the safc for cheap... Is this w... Nov 18, 2008 - 8:17 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 8th, 2026 - 10:10 AM |
