> Changing oil
post Oct 26, 2008 - 10:51 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
I know it's an elementary question, but I just need some opinions. I've put around 4000 miles on her and I'd like to keep everything as spry as possible, so therefore I'm going to have the oil changed regularly. How many of you do it on your own, and how easy is it to do? I'm guessing I won't need more than a catch pan and a couple tools.
Also, I know it's not "totally" necessary to do this a lot, but it's not abnormal to change it every 3000 miles, even if the oil light hasn't come on yet?
3 Pages V   1 2 3 >
Replies (1 - 19)
post Oct 26, 2008 - 10:59 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
oh no no no. Its is very important to change the oil every 3,000 miles if not sooner. If you want your car to last its a must. If you keep up with regular maintenance then I will guarentee your motor will last up to 250,000 miles if not more.
I change my own oil, but I plan to take my car to toyota in the next month to get her ready for winter.
94 Celica gt white (sold)
post Oct 26, 2008 - 11:15 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Really? I've only ever heard of car enthusiasts talk about changing it at those times. Then why are services always scheduled in brackets of 10,000 or so miles?
post Oct 26, 2008 - 11:28 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
why wouldn't you want clean oil in your car lubbing all your internals up?
post Oct 26, 2008 - 11:32 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Yeah, try for 3000, just better that way (although you might not see a need to) and a good habit to get into. As far as changing the oil, thats real easy. Get one of those drip pans that double as a container (makes transport to oil recy easier). Pretty much warm up the motor a bit, jack it up, pop the bolt and watch it drain. Dont forget to dothe oil filter as well.
post Oct 26, 2008 - 11:43 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Like I've said time and time again, the 3k mile oil interval change is a scam and a hoax. Today's oils will easily last 10k+ miles even under daily city driving. Read this thread for some more insight:
http://www.supramania.com/forums/showthread.php?t=70780
I just did my oil change at 9k miles (Pennzoil Platinum Synthetic).
-Matt
post Oct 26, 2008 - 11:48 AM
mr-belowaverage
Joined Feb 4, '07
From Ontario, Canada
QUOTE (RickJamesBish @ Oct 26, 2008 - 11:51 AM) *
OH MY GOD. That's not an oil light, that is an oil pressure warning light and it means your car doesn't have sufficient oil pressure to lubricate the engine at that moment. It means turn your engine off immediately and put oil in there and don't restart it until everything is ok. It does NOT mean start thinking about maybe swinging by jiffy lube next weekend.
QUOTE (GotToyota @ Oct 26, 2008 - 12:43 PM) *
The lubricating properties of today's oils, conventional and synthetic, will remain even after 10k miles, yes. BUT the dirt debris and contaminants that your oil filter removes will saturate that filter within 3000 miles every time. Especially if you're driving the average Toyota four, with its poor piston rings.
Basically, your oil becomes more and more like dirty unrefined oil as you drive. All the dirt in it is damaging your engine like death by pin pricks. Change you oil regularly if you like your engine.
post Oct 26, 2008 - 11:52 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Read that thread then get back to me.
post Oct 26, 2008 - 11:56 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Here, I'll quote it myself for those too lazy to read:
Originally Posted by kindasad.gif/www.sae.org
"Title: Extended Oil Drain Intervals - Conservation of Resources Or Reduction of Engine Life (Part Ii)"
After reading that you may never change your oil again at even 10,000 miles!
There are millions of miles of oil analysis that not only prove short duration changes increase wear but also result in a lack of additive activation in the motor. If you own a Jiffy Lube then I would expect you to subscribe to the "3,000 mile Mentality" myth.
Oil additives are activated by heat and pressure. Due to the additives having to hold up over time i.e. longer than 10,000 miles the formulations take a certain period of time to become active in protecting the motor. Draining the oil at lets say 3,000 miles simply means the additives have just become active at the point you are draining your oil! In other words you are increasing wear by about 500% doing 3,000 mile drain intervals!
Oils that carry the extended drain ratings such as 506.01, 507.00 etc mean that the additives are formulated to remain active for periods up to 2 years, 40,000 kms or 640 hours of usage. Oils like Mobil 1 0w40 are formulated to withstand 400F sump temps WITHOUT breaking down and losing viscosity. Furthermore the oils cannot break down due to the PAO makeup of the oil. These oils do not rely on elastomers like the conventional oils do. This means that the oil can fully protect your motor at any temperature without the concern of thermal break-down and thinning out of grade.
If you doubt the 10K oil change intervals perform an oil sample at 1,000 miles. Most cars with a fresh sump of oil will peak out at the 1,000 mile mark. After that the wear metals may increase by only 5-10% over the course of 10,000 miles! Nearly 90% of the engine wear occurs in the first 1,000 miles on an oil change! Increasing oil change frequency increases the duration your engine spends in the activation period of the additives and greatly increases the damage in your motor from failing to follow the guidelines of the manufacturer.
Just looking at iron in a VW motor typical readings are around 20-35 ppm after 15,000 miles of use maximum on a motor that has more than 60,000 miles. The oil filter is not capable of filtering this much metal simply because the wear metals are so small they can't be filtered from the oil. Also because there is so little wear metal you do not get wear as a result of the metal being suspended in the oil.
Dispersants require time to bond to the wear metals and byproducts in your engine oil. As byproducts such as soot (gasoline or diesel make soot just different sizes which discolor the oil) are created additives coat them and prevent them from clumping and becoming larger. Typical soot particles in diesel oil are in the nanometer range in terms of size 10 times smaller than what any bypass filter can even capture which is rated at 2 microns absolute. Your oil filter in your motor is rated at capturing particles in the 7 micron range with only a 75% first pass rating...Bottom line is your car would last forever if you change the oil every 20,000 miles and NEVER replace the oil filter simply because your motor is not making enough metal or by-products to ever get captured! Oils especially those for diesels can handle upwards of 8% soot, that my friend is a LOT of soot! To put that in perspective a typical motor after 25,000 miles without an oil change or filter change will only have 1% soot in the oil. This oil will appear tar black yet the oil still has 80% of its rated levels of protection remaining!
Most oils are limited by time in the sump rather than miles due to sulfur in the fuel. Most gasoline motors can safely go 2 years between changes when using quality oils formulated for extended drains such as Mobil 1 0w40 and Truck and SUV 5w40. These oils along with those sold as VOW 506.01 have very high TBN ratings that neutralize acid formation for upwards of two years (1 year in diesels due to higher sulfur content which causes the acids).
Here's the deal, forget the myths about frequent oil changes and basing your perceptions on how the oil looks. The best advice is use a quality oil and drain it at the specified interval. The worst thing you can do to a modern car is over maintain it, yes this is possible due to the very specific regimen that VW engineers figured out to keep your car running at peak performance with maximum durability.
Basically you're putting MORE wear on your motor changing it at 3k miles because the additives in the oil have just activated or haven't activated at all.
-Matt
post Oct 26, 2008 - 12:03 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
I use Mobil 1 Supersyn (fully synthetic) and I change my oil every 7000miles, I would go longer but with 238,xxx miles I'd rather not. And surprisingly, the oil remains clean, and still translucent, nowhere near black.
I use the Fram extended guard filter. And I must say, surprisingly, even though people think fram is at the bottom of the list, this filter cleans the oil extremely well. If you are using conventional oil, i would agree with the 3000 mile thing, cause that turns into sludge soon after 3k.
But if you are spending your money on synthetic, you are wasting your money by changing your oil every 3k, it is designed to be changed at longer intervals.
This post has been edited by samir0189: Oct 26, 2008 - 12:03 PM
My F/S Thread!
Ferdi says (11:29)
post Oct 26, 2008 - 12:24 PM
samir0189
Joined Mar 8, '08
And Gottoyota is right, but only in cases where you are using a good quality oil. Amsoil's site states that for its 0w-30 oil..
Service Life
AMSOIL Signature Series 0W-30 Synthetic Motor Oil is recommended for extended drain intervals in unmodified(1), mechanically sound(2) gasoline fueled vehicles as follows:
• Normal Service(3) – Up to 35,000 miles or one year, whichever comes first.
• Severe Service(4) – Up to 17,500 miles or one year, whichever comes first.
And the oil filter is changed at the same interval. It all depends on what oil you are using.
My F/S Thread!
Ferdi says (11:29)
post Oct 26, 2008 - 12:27 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Yep, I'm currently using 10W-30 Amsoil, but the interval is 24,000 miles or one year instead of what you have above.
post Oct 26, 2008 - 12:51 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
QUOTE (Spider77 @ Oct 26, 2008 - 12:32 PM) *
Okay, I will do that. What oil do you guys use/recommend, and where is this drain located exactly? And would the jack that came with the car (to change the tire) be fine, or would I need something else?
QUOTE (mr-belowaverage @ Oct 26, 2008 - 12:48 PM) *
Thanks for clearing that up, you're a little sensitive on the subject? tongue.gif
post Oct 26, 2008 - 1:14 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
fram has gotten beter, they now remanufacture honda oil filters
post Oct 26, 2008 - 1:27 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (RickJamesBish @ Oct 26, 2008 - 12:51 PM) *
Please don't change it every 3k, I beg you. You are doing your engine more harm than good.
-Matt
post Oct 26, 2008 - 1:54 PM
samir0189
Joined Mar 8, '08
QUOTE (GotToyota @ Oct 26, 2008 - 1:27 PM) *
QUOTE (RickJamesBish @ Oct 26, 2008 - 1:51 PM) *
You don't really need to jack it up unless you have a larger build/body type or unless your car is lowered.
QUOTE (LewFX @ Oct 26, 2008 - 2:14 PM) *
Glad to hear that! I constantly get "OMG you use fram?!" from everyone. But I really don't see it as being all that bad, plus I don't live extremely close to a dealership to get OEM filters, and Fram is like the only other one in stores.
My F/S Thread!
Ferdi says (11:29)
post Oct 26, 2008 - 3:59 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (GotToyota @ Oct 26, 2008 - 2:27 PM) *
-Matt
i dont see how it would at all.
a jack is not necessary. just get a low profile catch that will fit underneath the car.
エキサイティングカーレーシングチーム!
post Oct 26, 2008 - 4:12 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Okay, that works. So where is that bolt located exactly? And what oil do you guys use?
post Oct 26, 2008 - 5:33 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
any 10w-30. penzoil castrol your preference. i used castrol.
look under the car and there is a 14mm (ithink or 12) bolt at the bottom of the oil pan. its pretty hard to miss
エキサイティングカーレーシングチーム!
post Oct 26, 2008 - 6:27 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: August 28th, 2026 - 5:03 AM
