> Acceleration vibrations, FIXED! - CV drive axles.
post Oct 27, 2008 - 8:24 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
Quite recently I've have this vibration, where the entire car shakes once I'm doing greater than 50+mph in gears 3-5(duh), ONLY during acceleration. Its really weird. I intend to get my wheel balances checked soon, although I have my doubts as this being the shaking stops if i coast/brake at the same speeds. There are no issues with turning etc, as I try not to at 70mph.
Also the problem sometimes disappears for short periods of time, and just that, the vibrating stops! Very odd.
I have had my motor mounts changed recently, for the record. Any suggestions?
This post has been edited by samir0189: Nov 26, 2008 - 7:39 PM
My F/S Thread!
Ferdi says (11:29)
- samir0189   Acceleration vibrations   Oct 27, 2008 - 8:24 PM
- - Add45   i have the same problem except mines around 60mph   Oct 27, 2008 - 8:35 PM
|- - samir0189   QUOTE (Add45 @ Oct 27, 2008 - 8:35 P...   Oct 27, 2008 - 8:38 PM
- - RickJamesBish   I was gonna say, something to do with the motor fo...   Oct 27, 2008 - 8:39 PM
|- - samir0189   QUOTE (RickJamesBish @ Oct 27, 2008 - 9...   Oct 27, 2008 - 8:42 PM
- - Add45   my car idles terribly as well   Oct 27, 2008 - 8:47 PM
- - RickJamesBish   But if it was an axle, you'd be having this pr...   Oct 27, 2008 - 8:50 PM
- - samir0189   QUOTE (Add45 @ Oct 27, 2008 - 8:47 P...   Oct 27, 2008 - 8:54 PM
- - 95celgt   yea, have this too, i first changed the motor moun...   Oct 28, 2008 - 4:31 PM
|- - CaliJeff   QUOTE (95celgt @ Oct 28, 2008 - 2:31...   Oct 28, 2008 - 4:39 PM
- - RickJamesBish   I forgot about the tranny, and he's probably r...   Oct 28, 2008 - 8:17 PM
- - Remy   If your car shakes going 50+ most likely you just ...   Oct 28, 2008 - 8:24 PM
- - samir0189   Yeah I really need to get the wheels rebalanced to...   Oct 28, 2008 - 9:28 PM
- - nutmeg   I had a problem like this for almost two years, bu...   Oct 29, 2008 - 7:03 PM
- - CaliJeff   Once again, like nutmeg said and I said, i think i...   Oct 30, 2008 - 12:18 AM
- - GotToyota   Get them balanced and go from there. That is the f...   Oct 30, 2008 - 12:25 AM
- - samir0189   I had the wheels balanced today. the problem still...   Oct 30, 2008 - 3:37 PM
- - GotToyota   Have you considered that it could be the motor mou...   Oct 30, 2008 - 8:21 PM
- - Batman722   QUOTE (samir0189 @ Oct 27, 2008 - 9...   Oct 30, 2008 - 8:38 PM
- - Bitter   test for motor mounts: jack engine up slightly wit...   Oct 30, 2008 - 8:43 PM
- - samir0189   The mounts were changed really just recently, with...   Oct 31, 2008 - 12:00 AM
- - samir0189   A bit of an update i guess: Today i had a 4 wheel...   Nov 3, 2008 - 5:03 PM
- - samir0189   Well guys, I did some extensive research and i...   Nov 3, 2008 - 8:10 PM
- - Remy   ^^^ yes thats true your boots don't have to be...   Nov 3, 2008 - 9:56 PM
- - samir0189   +1 so far.   Nov 3, 2008 - 10:11 PM
- - CaliJeff   update?   Nov 4, 2008 - 11:22 AM
|- - samir0189   QUOTE (CaliJeff @ Nov 4, 2008 - 12:2...   Nov 4, 2008 - 11:25 AM
- - nnesto   I had a similar problem a few years ago it was onl...   Nov 22, 2008 - 10:36 AM
|- - samir0189   QUOTE (nnesto @ Nov 22, 2008 - 11:36...   Nov 22, 2008 - 2:10 PM
- - samir0189   WOOT! I fixed it guys! I had both my CV dr...   Nov 26, 2008 - 5:35 PM
- - Cutrara   QUOTE (RickJamesBish @ Oct 28, 2008 - 8...   Nov 27, 2008 - 12:35 PM
Lo-Fi Version Time is now: August 27th, 2026 - 5:55 AM
