> Syncros, darn
post Sep 28, 2003 - 10:48 AM
blkGT
Joined Jun 10, '03
From FL
So I believe my syncros are shot. The stick rattles in gear and has plenty of space. I was wondering, i want to get a shortshifter.. would it be easier to install that and the syncros at the same time? What exactly do they do? Any info would help, i dont know anything about them.
Replies (1 - 3)
post Sep 28, 2003 - 11:18 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
syncros are inside the tranny. installing a short shifter has nothing to do with them.
and usually, bad syncros make for grinding noises when you shift.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 28, 2003 - 11:26 AM
blkGT
Joined Jun 10, '03
From FL
my lack of knowledge is showing. Then what is it that is making my chifter slide around... sometimes it even slides out of 5th gear
post Sep 28, 2003 - 11:45 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (blkGT @ Sep 28, 2003 - 8:26 AM)
worn out shift gates maybe.
a trd short shifter replaces the whole shifting asembly if i remember correctly. that might help the problem.
take off the shift boot and look at how the shifter sits when in the gears, that way you might be able to see exactly what/where the problem is.
Lo-Fi Version Time is now: September 15th, 2026 - 12:17 AM
