Nov 3, 2008 - 8:43 PM
![]() Enthusiast ![]() ![]() Joined Feb 20, '08 From Abingdon, Maryland Currently Offline Reputation: 7 (100%) |
So i was driving to school like any other day and when i parked my car, i noticed it seemed like my gears were locked up. I didn't really think much of it and just turned my car off and went to class. Finished class and came back to my car to drive home, *note*-my car was in first when i started it*, so i drove off and all the way home fine, about a 30 mins drive down the highway. When I'm almost home, i stop to get some gas and when i start the car back up, it starts up real shaky and I can't shift into any gears. I turn the car off and notice i can shift through all the gears perfectly when it's off, so i put it in first and start it back up, the car immediately starts moving when i start it. I end up driving the car home in 2nd, not stopping the whole way cause if I do the car will stall. If I shifted gears while driving, it was really rough, like i'm powershifting into gears.
I figure, it's gotta be the low fluids, air in the system, clutch slave, clutch master, or the clutch itself. So I knock out the easy one's first. Fluid was good and I bled the system, still can't shift. Before I go spending any money, I try testing the clutch to see if that is the problem. I start the car in 5th and drop the clutch, the car stalls out right away, so I figured the clutch was still good, especially since it hasn't been slipping or anything lately. I replace the clutch slave, thought what the heck, 19 bucks...didn't help though, so I try replacing the clutch master. Re-bled the system after putting the clutch master in, but that didn't help either. Lastly, I try adjusting the clutch master behind the clutch pedal, thinking maybe it isn't pumping enough fluid, but that didn't make a difference either. The only think I could think it would be is if the line for the fluid between the slave and master is leaking somewhere, but when I press in the clutch and hold it, I notice that the clutch slave is holding constant pressure, so I don't think there is a leak in the line. I am all out of ideas, I'm assuming now that it's something with the clutch, it has to be.... anyone else have any ideas before I take it to the shop to pay massive labor cost? |
Rymaster Gears lock up when the car starts, any ideas? Nov 3, 2008 - 8:43 PM
Rymaster okay, so I just read Griffgirl's older thread ... Nov 3, 2008 - 10:17 PM
GriffGirl Yeah, it totally sounds like what happened to me. ... Nov 4, 2008 - 8:04 PM
PHLCELICA New clutch. Happen to me already. Try and save up ... Nov 4, 2008 - 8:20 PM
Rymaster I live in Harford County Maryland, Abingdon to be ... Nov 5, 2008 - 10:56 AM
GriffGirl If you want to put in something that will go the d... Nov 5, 2008 - 12:30 PM
Rymaster It's actually north east of Silver Spring/Rock... Nov 5, 2008 - 9:54 PM
Rymaster i ended up putting the clutch in myself, at my bro... Nov 9, 2008 - 4:45 PM
dagreat1 Wow I have the exact same problem you do... I went... Nov 13, 2008 - 2:04 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 29th, 2026 - 8:05 AM |
