> Which 3sgte engine to use?
post Sep 28, 2003 - 9:14 PM
venomviper88
Joined Aug 29, '03
From california
which 3sgte engine would you guys use. Would you guys get a gt-4 engine from japan or would u guys get it from a mr2?
post Sep 28, 2003 - 9:45 PM
Guest_Matthew_*
http://www.6gc.net/forums/index.php?showtopic=1448
get a st185 front clip
post Sep 29, 2003 - 12:07 AM
dont get an mr2, stick with a celica engine. St205 or St185, difference of about 2500. USDM engines have higher mileage, get a clip, get jdm.
post Sep 29, 2003 - 11:14 PM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
i saw somwhere on this forum (i cant find it now) that the 4th generation celica alltrac has the same 3s-gte that a 2nd generation gt4 has. is this true? and if so what year range is the 4th generation?
post Sep 30, 2003 - 1:04 AM
Guest_Matthew_*
there isnt a 4th generation gt4/all trac that i have ever heard of
there is a 4th generation 3s-gte. thats in the toyota caldina. chassis code st215. i think 260hp or so. way expensive and super rare and even more to do the wiring to swap into your car.
1st gen 3s-gte in the all trac/gt4 st165 87-89 (i think)
2nd gen 3s-gte in the all trac/gt4 st185 90-93
3rd gen 3s-gte in the gtfour 94-98 st205
4th gen 3s-gte in the caldina not sure on years st215
post Sep 30, 2003 - 1:28 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (GT2GT4 @ Sep 29, 2003 - 10:04 PM)
the very first alltrac came out with the 4th gen celica. 86-89 or something like that. came with the 1st gen 3sgte and a small w2a IC
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 30, 2003 - 4:55 AM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (GT2GT4 @ Sep 29, 2003 - 11:04 PM)
4th gen 3s is in the new Caldina, ST246... the ST215 has a 3rd gen...
post Sep 30, 2003 - 9:47 PM
venomviper88
Joined Aug 29, '03
From california
is there any way you could leglize a swap from either a mr2 or a gt-4?
post Oct 1, 2003 - 12:53 AM
Guest_Matthew_*
QUOTE (97sccelica @ Sep 30, 2003 - 12:28 AM)
umm yea thats what i said
he said 4th Gen all trac/gtfour
not 4th gen celica
read the post before you say i am wrong
post Oct 1, 2003 - 12:54 AM
Guest_Matthew_*
QUOTE (kuya1284 @ Sep 30, 2003 - 3:55 AM)
yea i didnt know there was a new caldina
only have heard of the st215
either way
for most people its best to use the st185 engine
post Oct 1, 2003 - 10:54 PM
DustyBurns30
Joined Jul 31, '03
is it still easier to use a st185 engine over any other when you get a front clip? given that there are some parts that have to be perchased or replaced, cant you just gut the clip for the ecu, gauge cluster, wiring harness, shift linkage, components, motor mounts and not have a problem with wiring? i mean, the only wiring complications involved when your going that route is lighting and power options, right?
post Oct 1, 2003 - 11:22 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
get the 185... you can get replacement parts from toyota for the most part just use the 5th gen alltrac for ordering.. I have a 205 and it was a pain to get replacement parts for the top end.. toysport wanted 350+ just for a new heat shield F@*k that!... currently I am playing around with a 185 top end I got when I traded my GT4 rearend parts, so far everything I have order for it from the toyota dealer has worked fine... did have alittle bit of a problem with the oil return hose but a little bending fixed that fine and it could of just gotten bent in shipping.
Lo-Fi Version Time is now: May 1st, 2026 - 6:40 PM
