Nov 8, 2008 - 2:35 AM
Enthusiast ![]() Joined Oct 2, '08 From New Zealand Currently Offline Reputation: 0 (0%) |
Hi All
This the work I have done today on my Car My Old Battery Leads ![]() Engine Bay ![]() New Battery ![]() Positive Terminal ![]() Negative Terminal and Temporary Ground Wire (Will be replaced with Blue 4 Gage Cable When I do the BIG 3) ![]() New 8 Gage Cable and 60Amp Fuse for Sub ![]() I'll be taking photos of my New Blue Interior tonight when it's dark. This post has been edited by WWSideWinder: Sep 1, 2009 - 4:36 AM -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
![]() ~ signature made by jaws4god ~ Have a look at my thread for updates on my progress. "http://www.6gc.net/forums/index.php?showtopic=63338&hl=0" |
Nov 8, 2008 - 6:01 AM
Previous work done to car.
New Head unit ![]() Unfortunately it has green lights and now my Dash is Blue 6.5" Pioneer 2 way at the Back ![]() 6.5" Nova 3 way in the Doors ![]() Tweeters on the Doors ![]() ![]() Old 12" Sub in the Boot (Will post Pic is any one wants to see it. Still working on the Dash Lights will post when I have them done. Comments / Suggestions / Flames ? -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 8, 2008 - 8:46 AM
Finally Some Pictures of the Blue Dash
Gages ![]() Center Console. Head unit is GREEN ![]() Auto Selector ![]() Climate Control Blue Back Ground and Blue Selected Lights ![]() ![]() This is Still a work in Progress as you can see there are more green lights to change. ![]() If any one is interested on how I have made these changes just ask. Things to do Still: - Change all the Green Lights to Blue - Boot and Cubbyhole to Blue - Dome light Dimmer and Key light on when door is opened and on Dimmer Circuit - Blue Under Dash Lights on Open Door - Look at Blue Dome Light - Digital Volt, Amp, Oil Temp and Pressure to make and test This is a mock up of the Digital Gages I working on. (Digits are Yellow for now,I trying to source blue ones. ![]() -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 8, 2008 - 9:01 AM
I have a video of my Dash at YouTube
"http://www.youtube.com/watch?v=NPibXhKQhWI" -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 10, 2008 - 12:13 AM
Comments, Suggestions, FLAMES......
Anyone???? -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 10, 2008 - 2:12 AM
Enthusiast ![]() ![]() Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) |
It may be dumb to ask but is pressure spelled wrong in the one gauge or is it spelled preshure in New Zealand. Nice work by the way I like the blue ac controls. I want to do mine in blue. Did you use leds or the film method?
Nov 10, 2008 - 2:24 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '08 From Christchurch New Zealand Currently Offline Reputation: 0 (0%) |
its spelled pressure. nice spotting. it that made or photochoped?
-------------------- ![]() 1994年 トヨタ 神々しい My Facebook My Bebo QUOTE (loll6g @ Nov 6, 2008 - 5:53 AM) automatics are for lazy ass drivers who jst want there car so that they can look cool |
Nov 10, 2008 - 2:28 AM
I thought it was pressure but I was just checking. I'm in the us but I know that different countries sometimes spell the same things differently
Nov 10, 2008 - 2:59 AM
My Bad Spelling. Yes it should be Pressure.
As to the ac control's I've used both. 1) I have replaced the Green 3mm with Blue 3mm 1200MCD (Super Bright) 2) I have cut stripes of Dark Blur Gels and folded them 4 times to make a "hood" for each LED so that they don't dazzle me. When I had just the LED with no "hood" it was so bright you could not see the blue background and With the lights off it distracted me during the day. If you ask nicely I'll get photos of the unit for you to see (OK OK all you actually have to do is ask.) As to the Photo it's a photo and MS Paint Touch-up. I'm in the process of building the Gages and I hope to have a prototype Voltmeter in the next 2 to 3 weeks. So Besides the Spelling ! Any other Comments. -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 10, 2008 - 1:59 PM
I'd like to see more photos please.
Nov 11, 2008 - 12:06 PM
OK photos on Updating the AC unit with LED's
AC unit and Implements of Destruction I used for the job ![]() Ready to Disassemble ![]() Testing the LED's and getting the polarity correct ![]() Inserting a LED ![]() LED's inserted and ready to solder (Not long and short pins ![]() Making the Hoodies 1) Cut the Gel into a thin strip ![]() Fold in 1/2 ![]() and 1/2 again ![]() Insert 1 end of the hoody between the LED and the Plastic Support ![]() Carefully bend the Gell and insert between the LED and Plastic Support on the other side. ![]() I have left the Full Fan LED un-hooded to try and show you how bright it is but the photo will not show the difference very well. ![]() The best thing to do would be to go to your locak electronics store and compare the normal LED to the Super bright and then you will understand. I hope this will help and inspire people out there to attempt this mod as it makes a BIG difference to the look of the AC Unit and the Dash as a whole. -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 11, 2008 - 12:17 PM
As well as the Above AC change last night I added Blue under LED's to both Driver and Passenger foot wells
![]() The photo is darker than in real life. Added Blue LED's to the Dome Light ![]() I have added the LED to the Normal dome light, Both LED'a and Dome light have separate switches and both are trigged buy opening the door/s ![]() I have added to the dome light rather than replacing it so that I can get White light to search for stuff and use the map lights. Part 2 of this is to build and install a delay dimmer circuit that will leve the lights on fo 15 seconds then dim but will immediately dim when I turn the key to ACC. Next on the list is to and more LED's to the AC unit (Secret till finished) and add some LED's to the boot. I have changed the Cubby and Ashtray to blue so all that is left is the boot (I have a Coupe) -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 11, 2008 - 2:20 PM
Nice work there! Would you mind removing the clear plastic cover from the dome light and taking a picture of the lights in there? I like the idea of what you've done there but am having a hard time understanding what exactly/how you did that. I HATE my dome light - it's the worst yellow EVER! I actually want to change mine to be bright white, but I'd really like to see what you've done.
Nov 11, 2008 - 4:39 PM
nice pics thanks. what did you use for the main back lights the ones that come on with the headlights. I like the dual dome light. I think it would look really good if you replaced the stock bulb with super white led array.
Nov 11, 2008 - 6:55 PM
T10 wedge
6 forward facing led T5 wedge 3 Led in a circle I'll try and find pic's of them. -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 11, 2008 - 7:13 PM
2 x T10 "http://monu.co.nz/index.php?productID=33" these are the people iI bought them from so this is the one in my Car
T5 x 4 "http://www.ledlight.com/t5-wedge-3-led-light.aspx" this is like the ones I have -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 11, 2008 - 9:56 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 21, '08 From Naples, FL Currently Offline Reputation: 0 (0%) |
New head unit and it's already laden with finger smears and smudges.
Nov 11, 2008 - 10:04 PM
LOL
Have to take it off or it will get stolen.... Sunday I will be washing and Polishing the Car as well as the dash (and Head unit) -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 12, 2008 - 2:36 AM
My Dome Light
What I did is I drilled 2 holes and inserted 2 bright blue LED's The small glass looking things. This way I have the best of both worlds, Blue light and White light. I have mounted a small switch on the dash to turn the blue LED's on or off. ![]() Hope this helps, If you cant see them tell me and I'll ring them in red or something. -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
Nov 12, 2008 - 2:46 AM
Better labeled photo.
| Lo-Fi Version | Time is now: August 31st, 2026 - 2:09 AM |
