> Wondering, 3sfe and 5sfe tranny compatibility
post Nov 14, 2008 - 7:29 PM
trdproven
Joined Aug 2, '05
From Guam
I have a 5sfe auto trans celica, but I want to convert it to manual trans. Will a 3sfe tranny mount up right to our 5sfe? Is it direct bolt on, will I need new axles, will modifications like drilling be needed, will it work at all?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 17, 2008 - 7:45 AM
trdproven
Joined Aug 2, '05
From Guam
Can I take everything I need from the 3sfe like shifter cable, clutch resevoir, all the little things and transfer them over? Or is it only the transmission itself?
Between the two checklist I found, what is what and what is needed really and from what model car specifically.
Here is the checklist from Doc *much shorter*.
Manual tranny
Flywheel and bolts
Clutch kit (and pressure plate bolts)
Driver's side mount for manual
Shifter assembly
Shifter cables
Clutch pedal assembly
Brake pedal (or grind down your stock one)
Clutch master cylinder
Clutch slave cylinder (if not included with tranny)
Clutch lines
Manual ECU or wire in resistor box for the auto ECU
Checklist from Sev408
-Transmission
-Shifter
-Shift Cables
-Flywheel
-Clutch Master cylinder
-Slave cylinder
-New clutch
-Clutch metal fluid lines
-Rubber clutch line
-Flywheel bolts
-Pressure plate bolts
-Clutch pedal assembly
-Manual brake pedal (just the pedal because John told me you dont need the whole assembly)
-Tranny fluid
-Brake fluid for clutch
-Manual Transmission Drivers Side Mount
-Starter Relay for Manual
-2 bolts for Trans- 12 by 1.25 (1 is 65mm other is 75mm)
-Manual ECU
(I bought it because I dont want to have a constant check engine light)
-Gear Greace
This post has been edited by trdproven: Nov 17, 2008 - 8:35 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 28th, 2026 - 7:50 AM
