Nov 15, 2008 - 2:38 PM
Enthusiast Joined Oct 25, '08 From Ireland Currently Offline Reputation: 0 (0%) |
basically, the damn thing doesnt feel like its going into gear at all, and it seems to swap between selecting a gear and not selecting at high rpm shifts.
any suggestions? |
Nov 15, 2008 - 2:46 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
check the linkage cables...maybe you did not fully reconnect them.
This post has been edited by Daftboy: Nov 15, 2008 - 2:46 PM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
Nov 15, 2008 - 2:52 PM
i didnt install the shifter mate it came from japan with it.. is it the cables at the bottom of the shifter aye?
Nov 15, 2008 - 3:44 PM
when you buy the short shifter it comes with a assembly and knob....there are four bolts that you need to unblot to take out the old one. There are also 2 shifter linkage cables i believe that are clip to it which is what controls the shifting to other gears. Just make sure that the cables are secure...post a picture of what you mean if you want so i can see what you mean .
Nov 15, 2008 - 3:47 PM
cool man thanks ill do that in the morning (its 9pm here), thanks!
Nov 25, 2008 - 3:55 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
If I remember correctly aren't there spacers that go under the shifter assembly at each of the 4 bolts to raise the thing up? It's been a long time since I installed mine.
-------------------- 1999 Celica GT
Nov 25, 2008 - 4:39 PM
Enthusiast ![]() ![]() ![]() Joined May 22, '08 From dallas texas Currently Offline Reputation: 11 (100%) |
ya there are, you remove the stock ones with the assembly, also we used the stock shift linkages/cables etc....works fine
| Lo-Fi Version | Time is now: July 31st, 2026 - 9:52 AM |
