Nov 16, 2008 - 6:33 PM
Enthusiast ![]() Joined Sep 2, '05 From delaware Currently Offline Reputation: 0 (0%) |
hi guys i have a 5sfte celica i had to replace my clutch out due to the more power from the turbo so i get the car done a start it up and it wont go into gear when first staring and when it does i let off the brake and the car pulls like the clutch isnt fully disengaging i tried bleeding the slave cylinder thinking air was in the system but still has the problem.
i have installed f1 racing clutch stage 2 fidanza lightweight flywheel new throwout bearing bleed slave cylinder put 40w gear oil in transmission adjusted clutch pedal free play |
1994toyotaracer clutch not disengaging Nov 16, 2008 - 6:33 PM
bslik possibly clutch master or slave cylinder is bindin... Nov 16, 2008 - 8:33 PM
1994toyotaracer QUOTE (bslik @ Nov 16, 2008 - 8:33 P... Nov 16, 2008 - 9:01 PM
garin the clutch could be set in the transmission wrong ... Nov 16, 2008 - 9:06 PM
1994toyotaracer QUOTE (garin @ Nov 16, 2008 - 9:06 P... Nov 16, 2008 - 10:05 PM
bccentaur3 You didn't put the clutch disc in backwards di... Nov 16, 2008 - 10:14 PM
1994toyotaracer QUOTE (bccentaur3 @ Nov 16, 2008 - 10... Nov 17, 2008 - 7:37 AM
Cuts_the_Pilot I had this problem also.
i made a silver steel sla... Nov 17, 2008 - 7:47 AM
presure2 QUOTE (1994toyotaracer @ Nov 16, 2008 - ... Nov 17, 2008 - 7:50 AM
1994toyotaracer QUOTE (presure2 @ Nov 17, 2008 - 8:5... Nov 17, 2008 - 9:22 AM
presure2 QUOTE (1994toyotaracer @ Nov 17, 2008 - ... Nov 17, 2008 - 10:00 AM
1994toyotaracer QUOTE (presure2 @ Nov 17, 2008 - 11... Nov 17, 2008 - 10:27 AM
presure2 QUOTE (1994toyotaracer @ Nov 17, 2008 - ... Nov 17, 2008 - 10:34 AM
1994toyotaracer QUOTE (presure2 @ Nov 17, 2008 - 11... Nov 17, 2008 - 10:43 AM
1994toyotaracer new info
i can put it in gear when the car is off ... Nov 17, 2008 - 12:19 PM
GriffGirl It's definitely the clutch then. Maybe you got... Nov 17, 2008 - 1:41 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 6:56 PM |
