Nov 20, 2008 - 10:52 PM
Enthusiast ![]() Joined Apr 23, '08 From VEGAS Currently Offline Reputation: 1 (100%) |
ok so i want to put wheel spacers to get that wider look and get my wheels flush with the body,right now im rolling on a stock corolla-S 15 inch rims and it looks like its tucked in, my car is not dropped but looking to drop it with tanabe df210 soon, my question is how thick of a wheel spacer do i need to achieve that wider/flushed look?? any help and or suggetions? also where can i buy wheel spacers? any good brand in particular? any brand i should stay away from? all info regarding this topic will be greatly appreciated..
heres how it looks at the moment ![]() heres how the rims look like,sorry for the low quality pic..
Nov 21, 2008 - 12:27 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
good thread, id like to know exactly the same thing !
Like is there a conversion table for example, 15mm spacers = ?? additional offset This post has been edited by whatthe: Nov 21, 2008 - 12:28 AM -------------------- |
Nov 21, 2008 - 1:20 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
Yes, there is a conversion table, it's in the stickies.
Wheel offset guide. Basically, first thing you need to know is what offset your current rims are. After that, you need to know where you want your wheels to be. Then just buy the proper spacer. If you go anything thicker than a 10mm spacer, you should use extended wheel studs. -------------------- |
Nov 21, 2008 - 2:12 AM
Yes, there is a conversion table, it's in the stickies. Wheel offset guide. Basically, first thing you need to know is what offset your current rims are. After that, you need to know where you want your wheels to be. Then just buy the proper spacer. If you go anything thicker than a 10mm spacer, you should use extended wheel studs. thanks for your help! i didnt know that, i was looking to use 25mm spacer for the rear and 15 for the front... does anybody know a good quality brand and part numbers? -------------------- ![]() ![]() |
Nov 21, 2008 - 3:20 AM
I was going to go with H&R spacers myself because they come with the extended lugs, but you'll have to remove your old studs and put the new ones in. (which isn't a problem for me because I need to replace mine anyways).
An easier way to go is to get a set like these tc sportline spacers. They have the hub centric ring built in, and it's a complete bolt on spacer, so you don't have to remove your old studs at all. Here is the link for the tc sportline spacers I would recommend for you. 15mm spacer 25mm spacer **Also, are you running a 96-99 front bra on your Celica? -------------------- |
Nov 21, 2008 - 3:29 AM
I was going to go with H&R spacers myself because they come with the extended lugs, but you'll have to remove your old studs and put the new ones in. (which isn't a problem for me because I need to replace mine anyways). An easier way to go is to get a set like these tc sportline spacers. They have the hub centric ring built in, and it's a complete bolt on spacer, so you don't have to remove your old studs at all. Here is the link for the tc sportline spacers I would recommend for you. 15mm spacer 25mm spacer **Also, are you running a 96-99 front bra on your Celica? sweet MaskedMan! i really appreciate your help, and yes the front bra cover is for a 96-99,my uncle found it when the dealership he works at(fletcher jones toyota) was moving from the old building to the new building,the manager told him to throw it in the trash because they couldnt sell it and nobody wanted it so he took it and gave it to me,along with another bra cover for CRV..lol.. -------------------- ![]() ![]() |
Nov 21, 2008 - 7:56 AM
Sorry a little thread jacking. ..
http://www.tcsportline.com/web/pdut_detail...NO=000600040001 this product is probably exactly what im after, tho i have a question for thread size are ours 12x1.5 or 12x1.25? so i can use my stock toyota nuts oh yeh and it will fit on the celica correct? and these are hub centric so they wont fly out when i drive right....? lol -------------------- |
Nov 21, 2008 - 1:45 PM
Sorry a little thread jacking. .. http://www.tcsportline.com/web/pdut_detail...NO=000600040001 this product is probably exactly what im after, tho i have a question for thread size are ours 12x1.5 or 12x1.25? so i can use my stock toyota nuts oh yeh and it will fit on the celica correct? and these are hub centric so they wont fly out when i drive right....? lol Our thread pattern for our cars is M12x1.5, so you should be able to use your stock lug nuts. The hub centric part is just to help align the wheel onto the center of the hub. To keep your wheels from flying off, I recommend fastening your lug nuts down to the proper torque spec. This does not mean to tighten them as tight as humanly possible, or by using an impact gun on full blast -------------------- |
Nov 21, 2008 - 1:59 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
Expect your wheel bearings to wear out real fast with spacers like that!
Nov 21, 2008 - 2:44 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From san antonio tx. Currently Offline Reputation: 12 (100%) |
Hey masked man, whats the price on a 15mm spacer like the hubcentric one on that site?
-------------------- Sorry, no animated sigs allowed.
Nov 21, 2008 - 3:02 PM
Hey masked man, whats the price on a 15mm spacer like the hubcentric one on that site? The price for a set of 2 15mm spacers would be $99. The price for a set of 2 25mm spacers would be $119. (incase anyone was wondering about that too) -------------------- |
Nov 21, 2008 - 5:28 PM
I was going to go with H&R spacers myself because they come with the extended lugs, but you'll have to remove your old studs and put the new ones in. (which isn't a problem for me because I need to replace mine anyways). An easier way to go is to get a set like these tc sportline spacers. They have the hub centric ring built in, and it's a complete bolt on spacer, so you don't have to remove your old studs at all. Here is the link for the tc sportline spacers I would recommend for you. 15mm spacer 25mm spacer **Also, are you running a 96-99 front bra on your Celica? so im all good to use the 15mm up front and 25 for the rear right? and this will be plug and play? -------------------- ![]() ![]() |
| Lo-Fi Version | Time is now: August 28th, 2026 - 2:12 AM |
