> Sunroof troubles
post Nov 23, 2008 - 12:04 AM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
Ok, so I can slide it back and til it up with the motor. Now I am curious if anyone has had this problem, so here it goes.
It was fine last night, when I drive, I usually have it tilted up. Today, the button to tilt it up isn't doing anything. I push the button to slide it and it does nothing. I push the button to retract it as if I did slide it back and it tilts it up. I push to slide it back and it sets it back, but too low. So I push the button to tilt it and it sets it back in the right spot. That is the only working order it goes. If I hold the button past it tilting it to maximum, I get this buzzing noise like it wants to keep going but is stuck. If I close it and hold the button, it makes that same noise.
So I am wondering if I need a new motor, or if there is a problem in the wires for the switches. I took it apart, and I would think it is the wires in the switches, because the motor does operate, just getting the wrong signals. What do you think? Can you help? Suggestions on what the problem might be or what I need to replace?
Replies (1 - 4)
post Nov 23, 2008 - 9:20 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Could also be your relay. Check out the BGB stuff on celica tech here.
post Nov 23, 2008 - 10:55 AM
celica9110
Joined Feb 6, '08
From charleston, sc
i have the same issue
and i clicked the "here" button
and the diagram made no sense, probly because idk how to read that
myspace!!
go FULL THROTTLE or go home
post Nov 23, 2008 - 12:46 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Yeah, I have to admit, when reading a wiring diagram/schematic for the first time it looks rather daunting. Pretty much what you want to do before you start pulling and replacing parts is to troubleshoot the problem. Because you can replace one part, and that might not fix the issue, then your stuck replacing another part, hoping it fixes it. You can see how this could add up in the long run.
From the sound of your problem it sounds like a short, you can check the wires from the control switch to the relay, then relay to motor.
post Nov 23, 2008 - 9:31 PM
Random_Stranger
Joined Mar 20, '07
QUOTE (Spider77 @ Nov 23, 2008 - 9:46 AM) *
Thanks I will do that, and you are absolutely right. People usually mask the problem and not take the time to pin point it. Thanks.
Lo-Fi Version Time is now: August 12th, 2026 - 1:06 AM
