> 5SFTE with the 3SGTE Exhaust Manifold, How many studs?
post Nov 23, 2008 - 8:24 PM
RichieRichJP
Joined Feb 7, '08
From Colorado Springs, CO
For those who used the 3SGTE exhaust manifold on their 5SFTE set up, what Gen manifold is usually used?
From what I'm reading, the Gen 2 and Gen 3 ones are different because of the amount of studs used from the head.
I currently have a custom exhaust manifold that fits my Camry and it has 7 holes.
Thanks
post Nov 23, 2008 - 8:31 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
I used the one from a 2nd gen 3sgte.
post Nov 23, 2008 - 8:51 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
GEN2
330whp 309ft/lbs @ 21 PSI
post Nov 24, 2008 - 12:29 AM
aznpnoiboi55
Joined Nov 19, '07
From las vegas
gen 2
post Nov 24, 2008 - 4:34 PM
you need the early revision gen 2 90-92 the 93+ one has 9 bolt holes, and you will have to cut a nub off for it to fit.
post Nov 25, 2008 - 4:15 PM
RichieRichJP
Joined Feb 7, '08
Thanks guys!
I nearly **** myself when I found out Gen 2 and 3 3S heads had different amount of bolt holes.
Plus the person doing the wiring harness for me pulled one from a Gen 3 3SGTE, but I found out I can use either one for the AEM EMS.
So now I know to go Gen 2...
Lo-Fi Version Time is now: June 13th, 2026 - 3:44 PM
