> clutch Q's, 3sgte swap
post Nov 23, 2008 - 11:24 PM
silverceli09
Joined Nov 13, '08
From Indiana
ok i so i have learned that when i swap out my 5sfe for a 3sgte that i can use my stock tranny, i just need to get that hybrid clutch setup. now my question is. can i instead of doing the hybrid deal, could i just buy like a stage 2 or 3 clutch kit for the 3sgte? will that work? or do i have to use the hybrid set up?
Celica Or Die, check out http://www.redlinemotive.com!
post Nov 23, 2008 - 11:35 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
No because if you get a clutch kit specifically for the 3sgte the clutch disc wont work with the 5s trans.
You can get a kit from Dr. Tweak. The Doc will hook you up with a solid set-up.
Or you can order it individually 3s pressure plate and a 5s clutch disc and you'll be good.
This post has been edited by bccentaur3: Nov 23, 2008 - 11:36 PM
94 Celica gt white (sold)
post Nov 24, 2008 - 12:01 AM
silverceli09
Joined Nov 13, '08
From Indiana
QUOTE (silverceli09 @ Nov 24, 2008 - 12:24 AM) *
does the doc have a website?
post Nov 24, 2008 - 5:35 AM
QUOTE (silverceli09 @ Nov 24, 2008 - 12:01 AM) *
you can also have spec or ACT make you a 3s disk with the 5s spline.
in fact, ANY clutch company can set you up with a solid setup, just a matter of calling and telling them what you want.
Lo-Fi Version Time is now: September 13th, 2026 - 1:30 AM
