> mr2 pressure plate in celica?
post Nov 24, 2008 - 9:14 AM
silverceli09
Joined Nov 13, '08
From Indiana
will a pressure plate from a 3sgte mr2 work on a 3sgte swap?
Celica Or Die, check out http://www.redlinemotive.com!
post Nov 24, 2008 - 9:21 AM
QUOTE (silverceli09 @ Nov 24, 2008 - 9:14 AM) *
yes.
post Nov 24, 2008 - 10:29 AM
silverceli09
Joined Nov 13, '08
From Indiana
QUOTE (presure2 @ Nov 24, 2008 - 10:21 AM) *
yes.
ok sweet. now, since i have a 5sfe, i should already have the 5s disk. so all i really need is the 3sgte pressure plate. do i have to have a custom plate made, or will a normal 3sgte pressure plate work?
post Nov 24, 2008 - 12:22 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
normal one will work, all though I do not recommend you using your old 5s disc, because it won't be able to hold the power the 3s has. Your clutch will be slipping sooner or later.
94 Celica gt white (sold)
post Nov 24, 2008 - 12:38 PM
QUOTE (silverceli09 @ Nov 24, 2008 - 10:29 AM) *
yes.
i think you may have parts confused.
go to howstuffworks.com and research a bit, its a great way to learn how all that stuff works.
you need a 3sgte pressure plate, 3sgte clutch disk, with 5sfe (s54) splines, and the 3sgte flywheel.(resurfaced of course) you will also want a new throwout bearing also, as tweek discribed in your other thread.
Lo-Fi Version Time is now: September 12th, 2026 - 11:51 PM
