Dec 4, 2008 - 10:51 PM
Enthusiast ![]() Joined Nov 13, '08 From Indiana Currently Offline Reputation: 0 (0%) |
what are you referring to when you talk about installing LSD in your tranny? what is it?
-------------------- Celica Or Die, check out http://www.redlinemotive.com!
silverceli09 What is LSD? Dec 4, 2008 - 10:51 PM
GotToyota It's a drug. Dec 4, 2008 - 10:56 PM
silverceli09 QUOTE (GotToyota @ Dec 4, 2008 - 10... Dec 4, 2008 - 10:59 PM
whatthe QUOTE (GotToyota @ Dec 5, 2008 - 2:5... Dec 5, 2008 - 5:39 AM
GotToyota QUOTE (whatthe @ Dec 5, 2008 - 4:39 ... Dec 5, 2008 - 5:17 PM
bccentaur3 LSD= Greatness
LSD means Limited Slip Differentia... Dec 4, 2008 - 10:58 PM
samir0189 limited slip differential. It prevents "one w... Dec 4, 2008 - 11:00 PM
silverceli09 ohhhhhh...i see...thanks Dec 4, 2008 - 11:07 PM
97celiman yes but is it possible to "install" LSD ... Dec 4, 2008 - 11:13 PM
bccentaur3 You can by a differential to put inside the trans.... Dec 4, 2008 - 11:23 PM
97celiman so you could have a s54 with lsd...has anyone with... Dec 4, 2008 - 11:30 PM
Rusty came in standard SS-III (98+ or earlier version as... Dec 4, 2008 - 11:45 PM
bccentaur3 I forgot who, but someone used the mr2 spyder... Dec 4, 2008 - 11:55 PM
bslik i was told that my car has lsd when i bought it n ... Dec 5, 2008 - 4:48 AM
bccentaur3 QUOTE (bslik @ Dec 5, 2008 - 3:48 AM... Dec 5, 2008 - 11:01 AM
playr158 ^ that does not always hold true Dec 5, 2008 - 11:03 AM
bccentaur3 Yeah I know, but its one way you can kind of tell. Dec 5, 2008 - 11:06 AM
Supersprynt It's totally unreliable. That's no way to ... Dec 5, 2008 - 11:23 AM
bccentaur3 okay fine. Pull your axles and peak in there. With... Dec 5, 2008 - 11:27 AM
xredjokerx http://www.jdmuniverse.com/forums/nissan-i...lsd-v... Dec 6, 2008 - 7:21 AM
kbeaty do a sweet burn out and if you leave 2 rubber mark... Dec 6, 2008 - 8:25 AM
Rayme QUOTE (kbeaty @ Dec 6, 2008 - 9:25 A... Dec 6, 2008 - 12:15 PM
presure2 QUOTE (kbeaty @ Dec 6, 2008 - 8:25 A... Dec 6, 2008 - 9:19 PM
soulshadow A lot of cars don't have LSD, especially FWD b... Dec 6, 2008 - 6:28 PM
BonzaiCelica so i plan on doing a beams swap later on. But i sa... Dec 6, 2008 - 8:16 PM
bccentaur3 It the swap came with axles you don't really h... Dec 6, 2008 - 8:47 PM
BonzaiCelica alright then thanks for your replys Dec 6, 2008 - 10:03 PM
Rusty QUOTE A lot of cars don't have LSD, especially... Dec 7, 2008 - 12:16 AM
97celiman ok so what about quaife...is there a quaife applic... Dec 7, 2008 - 11:03 PM
GriffGirl If your car is jacked up in the front and you step... Dec 8, 2008 - 4:20 PM
KAOS I thought the Canadian GT-S models had LSD... no? Jan 5, 2009 - 11:15 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 14th, 2026 - 1:49 AM |
