Dec 6, 2008 - 4:51 PM
Enthusiast ![]() Joined Nov 15, '07 From Attleboro Mass Currently Offline Reputation: 1 (100%) |
Okay so heres the deal. My car is a 94 ST with a swapped in 7A (blew the other one up long story). So about a week ago I parked in front of my girlfriends house for about 3 hours, and when I came out to head home I got in my car and tried to start it. There was just one click and nothing else. My cooling fans turned on so some reason and now will not shut off until the key is in the off position.
So far I've replaced- Ignition Switch Starter Starter Relay and Fuse And now I am at my wits end to figure out what this is. The clutch safety switch is good. I've already searched the threads and came up with the same thing "change your starter". I did and it still dosen't work. So if anyione has had this same problem could you let a guy know what you did to fix it? Thanks in advance. Rick -------------------- QUOTE Surprise buttsecks always works fine for me. 1994 Toyota Celica ST 1977 Harley Sportser XLH 1992 Ford F-350 (plow truck) |
Dec 6, 2008 - 5:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
Where did you get your new starter from??How much did you pay for it?
Can u make it clip multiple times??say u try it once,click,then try again,click,then try again,click,try it again and finally it turns?.does it eventually start after you click it multiple times? -------------------- BANNED. for life, you moron.
Dec 6, 2008 - 7:00 PM
The starter was 174 minus a 50 dollar core charge. I got it from napa. The starter will only click once. And then nothing. Well except for the fans turning on at full speed. Once you roll the key back to off and then try again. Nothing will happen except for the fans turning on full speed.
Dec 6, 2008 - 8:55 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Is your battery charged up? If it is and you have replaced all the starting components, check your grounds.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Dec 7, 2008 - 1:51 AM
The starter was 174 minus a 50 dollar core charge. I got it from napa. The starter will only click once. And then nothing. Well except for the fans turning on at full speed. Once you roll the key back to off and then try again. Nothing will happen except for the fans turning on full speed. im asking,if u click,then turn the key back to acc,then try again will it click again?? -------------------- BANNED. for life, you moron.
Dec 7, 2008 - 2:07 AM
Will- Yeah my battery is fully charged. And I checked the grounds, all are fine no corrosion.
Cali- Just the fans turn on. No clicking from the starter only the relay. -------------------- QUOTE Surprise buttsecks always works fine for me. 1994 Toyota Celica ST 1977 Harley Sportser XLH 1992 Ford F-350 (plow truck) |
Dec 7, 2008 - 5:20 AM
Dec 7, 2008 - 12:24 PM
So you try to start the car and all that happens is clicking from the relay and the fan goes on? So when you take the key out of the ignition does the fan off or does it still stay on?
Can you try this for me? Take a 10 gauge wire, run ground it onto one of your starter bolts holding the starter in and the other end of the wire ground it to your chasis up front and try to start her up. -------------------- 98 Celica gt red- totaled deer
Dec 7, 2008 - 8:13 PM
Cali- Yes when I turn the key once it clicks, then when I roll it to off and then crank again it will just click once.
Will- I actually replaced all my ground wires with some 10AWG wire to day and I have three grounds going to the engine/tranny. And it stilll will not start. But I fixed the fan problem somehow. The wont turn on now when I turn the key on but I still can't start it. -------------------- QUOTE Surprise buttsecks always works fine for me. 1994 Toyota Celica ST 1977 Harley Sportser XLH 1992 Ford F-350 (plow truck) |
Dec 7, 2008 - 10:26 PM
hmm,bring the starter to auto zone or something and make sure it works!!!
Dec 7, 2008 - 10:56 PM
Do you have a ground on your starter and a power to fire your starter? Did you check your fuses?
Dec 7, 2008 - 11:00 PM
Since you replaced all your grounds it wouldn't hurt to add that ground I asked you to do.
Dec 7, 2008 - 11:46 PM
does it eventually start if u keep trying????
This post has been edited by CelicaST_CALI: Dec 7, 2008 - 11:47 PM -------------------- BANNED. for life, you moron.
Dec 8, 2008 - 9:15 PM
Will- That was one of the grounds I replaced. And I'm getting a consistant 12V power to the positive cable aa well as the other cable for the ignition.
Cali- Nope it won't start at all. -------------------- QUOTE Surprise buttsecks always works fine for me. 1994 Toyota Celica ST 1977 Harley Sportser XLH 1992 Ford F-350 (plow truck) |
Dec 8, 2008 - 9:17 PM
So you are getting one click when you try to start and then nothing?
Dec 8, 2008 - 9:28 PM
Yep just one click. But now I can hear my fuel pump priming. I was concern about the motor being seized, possibly from a leaky injector so I took all the plugs out and tried to start it but nothing just that one click.
Dec 8, 2008 - 11:54 PM
Add another ground for me. From motor to chassis and see if you get anything.
Dec 9, 2008 - 10:01 PM
Negitory. Still just that one damn click.
Dec 9, 2008 - 10:04 PM
Well you say you're getting power to your starter, but your starter relay is clicking? Have some one try to start the car and listen for the starter relay to click in your fuse box.
Dec 9, 2008 - 11:09 PM
there are 2 wires that go to your starter. a LARGE one that takes the charge and distributes it. and the Trigger wire, A smaller wire that goes to the side of the starter rather than the back. I willing to be that the trigger engagement wire is corroded or fell off. Was my problem before with the same symptoms.
This post has been edited by x_itchy_b_x: Dec 9, 2008 - 11:09 PM -------------------- |
| Lo-Fi Version | Time is now: August 28th, 2026 - 10:05 AM |
