Dec 6, 2008 - 4:51 PM
Enthusiast ![]() Joined Nov 15, '07 From Attleboro Mass Currently Offline Reputation: 1 (100%) |
Okay so heres the deal. My car is a 94 ST with a swapped in 7A (blew the other one up long story). So about a week ago I parked in front of my girlfriends house for about 3 hours, and when I came out to head home I got in my car and tried to start it. There was just one click and nothing else. My cooling fans turned on so some reason and now will not shut off until the key is in the off position.
So far I've replaced- Ignition Switch Starter Starter Relay and Fuse And now I am at my wits end to figure out what this is. The clutch safety switch is good. I've already searched the threads and came up with the same thing "change your starter". I did and it still dosen't work. So if anyione has had this same problem could you let a guy know what you did to fix it? Thanks in advance. Rick -------------------- QUOTE Surprise buttsecks always works fine for me. 1994 Toyota Celica ST 1977 Harley Sportser XLH 1992 Ford F-350 (plow truck) |
6GenCelicaST Car will not start Dec 6, 2008 - 4:51 PM
CelicaST_CALI Where did you get your new starter from??How much ... Dec 6, 2008 - 5:44 PM
6GenCelicaST The starter was 174 minus a 50 dollar core charge.... Dec 6, 2008 - 7:00 PM
CelicaST_CALI QUOTE (6GenCelicaST @ Dec 6, 2008 - 4... Dec 7, 2008 - 1:51 AM
bccentaur3 Is your battery charged up? If it is and you have ... Dec 6, 2008 - 8:55 PM
6GenCelicaST Will- Yeah my battery is fully charged. And I chec... Dec 7, 2008 - 2:07 AM
CelicaST_CALI your not answering my question...if u turn the key... Dec 7, 2008 - 5:20 AM
bccentaur3 So you try to start the car and all that happens i... Dec 7, 2008 - 12:24 PM
6GenCelicaST Cali- Yes when I turn the key once it clicks, then... Dec 7, 2008 - 8:13 PM
CelicaST_CALI hmm,bring the starter to auto zone or something an... Dec 7, 2008 - 10:26 PM
bccentaur3 Do you have a ground on your starter and a power t... Dec 7, 2008 - 10:56 PM
bccentaur3 Since you replaced all your grounds it wouldn... Dec 7, 2008 - 11:00 PM
CelicaST_CALI does it eventually start if u keep trying???? Dec 7, 2008 - 11:46 PM
6GenCelicaST Will- That was one of the grounds I replaced. And ... Dec 8, 2008 - 9:15 PM
bccentaur3 So you are getting one click when you try to start... Dec 8, 2008 - 9:17 PM
6GenCelicaST Yep just one click. But now I can hear my fuel pum... Dec 8, 2008 - 9:28 PM
bccentaur3 Add another ground for me. From motor to chassis a... Dec 8, 2008 - 11:54 PM
6GenCelicaST Negitory. Still just that one damn click. Dec 9, 2008 - 10:01 PM
bccentaur3 Well you say you're getting power to your star... Dec 9, 2008 - 10:04 PM
x_itchy_b_x there are 2 wires that go to your starter. a LARGE... Dec 9, 2008 - 11:09 PM
6GenCelicaST Itchy that was the problem. There was just a hint ... Dec 10, 2008 - 6:06 PM
x_itchy_b_x glad i could help. Dec 10, 2008 - 8:03 PM
CelicaST_CALI anytime ....the starter is the worst thing on the... Dec 12, 2008 - 9:59 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 2:24 PM |
