Dec 8, 2008 - 2:57 PM
Enthusiast ![]() ![]() Joined Nov 12, '08 From ohio Currently Offline Reputation: 17 (91%) |
hi just wondering what the easiest way to change the wiring harness on a 5s-fe do i have to remove the intake in order to get the whole harness off?
Decalsondemand easiest least confusing way to remove and change wireing harness!& Dec 8, 2008 - 2:57 PM
playr158 why are you removing an engine harness?
and the i... Dec 8, 2008 - 3:04 PM
Decalsondemand im completely changing the engine and the wires on... Dec 8, 2008 - 3:06 PM
playr158 then pull out the wires with the motor and swap th... Dec 8, 2008 - 3:09 PM
Decalsondemand ok i am thinking labeling them is a good idea? Dec 8, 2008 - 3:10 PM
playr158 labeling is the best idea....also if you have a di... Dec 8, 2008 - 3:11 PM
Decalsondemand ALL OF IT SEEMS EASY TO REMOVE JUST LOOKS A BIT TI... Dec 8, 2008 - 3:13 PM
Decalsondemand [ok got the harness off but i am thinking there ha... Dec 8, 2008 - 5:07 PM
presure2 yes, there is.
you disconnect it at the fuse box i... Dec 8, 2008 - 5:34 PM
lagos It helps if you remove the valve cover on the 5sfe... Dec 8, 2008 - 5:56 PM
Decalsondemand yeah i found that was the easiest way but the dist... Dec 8, 2008 - 6:03 PM
njccmd2002 the easiest and less confusing will be to paid for... Dec 8, 2008 - 9:23 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 12th, 2026 - 8:18 AM |
