Dec 10, 2008 - 6:00 AM
Enthusiast ![]() ![]() Joined Aug 28, '07 From france Currently Offline Reputation: 0 (0%) |
I need some information about the egr in our celis, how is ti supposed to work. does she work only in lower revs or not?
If we suppress/disable it, it should give a performane increase in low revs no? |
Dec 10, 2008 - 3:15 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
it works by letting exhaust gas back into the manifold, cleaning emissions slightly.
it hampers performance (as any emissions thing does). Only works under low revs/light load i think. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
Dec 11, 2008 - 11:24 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
It redirects an amount of exhaust gas into the combustion chamber, lowering the temperatures. It's at high temperature that NOx forms, which is a rather nasty compound. At wide-open throttle EGR is bypassed.
Dec 11, 2008 - 11:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
I plugged mine today with just a BB and i feel a power difference...i have a 7afe though..
edit:i got my check engine light with the egr code so my celi is to smart..haha This post has been edited by CelicaST_CALI: Dec 12, 2008 - 8:19 PM -------------------- BANNED. for life, you moron.
Dec 21, 2008 - 1:01 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
the only side effect of that is now you have to watch engine temperatures and also a clogged EGR with the emissions going into your exhaust directly are going to burn up the cats. So next time you get smogged, you bay out of luck
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Dec 21, 2008 - 6:11 PM
disabling it does NOT increase performance as it does NOT function during acceleration, only during part throttle cruising or deceleration.
disabling it CAN cause spark knock at part throttle cruising, due to the lack of cooling affect and due to the fact that the PCM is expecting it to be present and functional. -------------------- |
Dec 21, 2008 - 9:16 PM
I plugged mine today with just a BB and i feel a power difference...i have a 7afe though.. edit:i got my check engine light with the egr code so my celi is to smart..haha No you don't. It's all in your head because EGR isn't always on and... you'll now fail smog... good job. -------------------- "It's ok to be naked girl... I'm an artist!"
Dec 22, 2008 - 5:32 AM
Enthusiast ![]() ![]() Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
Ok so if the EGR valve only works during light loads why does the Cali Spec have different Performance figures than FED spec models?Isn't the EGR valve the Min difference between the two? If not what other differences does the Cali Spec have that the Fed Spec doesn't?
Dec 22, 2008 - 9:23 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
howstuffworks.com
FTMFW -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Dec 22, 2008 - 9:10 PM
Ok so if the EGR valve only works during light loads why does the Cali Spec have different Performance figures than FED spec models?Isn't the EGR valve the Min difference between the two? If not what other differences does the Cali Spec have that the Fed Spec doesn't? theres also an extra cat converter, different tune in the computer, and iirc slight difference in cam grinds. -------------------- |
Dec 25, 2008 - 2:35 PM
I plugged mine today with just a BB and i feel a power difference...i have a 7afe though.. edit:i got my check engine light with the egr code so my celi is to smart..haha No you don't. It's all in your head because EGR isn't always on and... you'll now fail smog... good job. i dont have smog thank you very much...(be jealous) and yes i did feel a lil difference when going from 0-65... -------------------- BANNED. for life, you moron.
| Lo-Fi Version | Time is now: September 15th, 2026 - 6:23 AM |
