Dec 10, 2008 - 5:06 PM
Enthusiast ![]() ![]() ![]() Joined Mar 22, '07 From Murphy, TX Currently Offline Reputation: 5 (100%) |
I was wondering if those who have replaced their passenger side axle with a new or remanufactured one ran into this problem. Did the one you purchase come with the bracket (bearing) where the two bolts are to be screwed in.
the ones i found at pepboys and o'reilly and Napa does not come with that bracket. When i had replaced it a 3 years back - i did not remember removing that bracket from old one to new one. I believe it came with the one i purchased. The store said I would have to remove the bracket from the old one, but it seems difficult to remove. Any help is appreciated This post has been edited by 2bcelica: Dec 10, 2008 - 5:29 PM |
Dec 10, 2008 - 5:13 PM
if it didnt come with one on the new axle, you'll need to have the old one pressed off the old axle then installed on the new one.
it "should" come with a new one tho...are you sure its the right axle? -------------------- Former Team 5SFTE pro member ;)
Dec 10, 2008 - 5:19 PM
if it didnt come with one on the new axle, you'll need to have the old one pressed off the old axle then installed on the new one. it "should" come with a new one tho...are you sure its the right axle? comparing side by side - its identical except without the bracket -- the only thing i was able to do was have the sales guy double check because I thought it was the wrong part too - but he confirmed several times -- even the online picture from napaonline.com shows it without the bracket. I'm not sure where I purchased mine last time, wished i could remember so I would reorder one from the same place. Thanks |
found the solution - after looking at the toyota axle diagram - there's a snap ring that you have to remove before you can hammer it out - off to the store to pick up the new part - thanks for the input though
| Lo-Fi Version | Time is now: September 12th, 2026 - 4:40 AM |
