> new turbo and short block build.
post Dec 13, 2008 - 9:16 AM
mooreofal
Joined Oct 22, '08
From spring
i finally got that gt2876r i was talking about and also bought a megasquirt. i decided to get into the bottom end and when i saw the rods i new they had to go.
http://corollacarclub.com/forum/showthread.php?t=6688
Replies (1 - 13)
post Dec 13, 2008 - 10:29 AM
nice. have you installed megasquirt before or is this your first time?
post Dec 13, 2008 - 8:00 PM
mooreofal
Joined Oct 22, '08
From spring
QUOTE (lagos @ Dec 13, 2008 - 11:29 AM) *
no i have never tried, this will be the first. but im pretty sure i have figured out how to run the spark with the guys at diyautotune.so we will see how it turns out.have you?
post Dec 13, 2008 - 8:54 PM
i havent yet...but i thought about doing it to my car.
post Dec 14, 2008 - 6:43 PM
mooreofal
Joined Oct 22, '08
From spring
what motor are you running?
post Dec 14, 2008 - 7:25 PM
3sgte... check my profile.
post Dec 15, 2008 - 7:16 AM
mooreofal
Joined Oct 22, '08
From spring
QUOTE (lagos @ Dec 14, 2008 - 7:25 PM) *
do you have a crankmounted crank position? or the 4-1 and 1-1 sensor in the dizzy?or is it completly different?
post Dec 15, 2008 - 11:29 AM
Thats the problem with our cars. Our crank position sensor is in the distributor and megasquirt has trouble reading it.
You need to convert to coil packs and get a crank trigger with wheel.
post Dec 15, 2008 - 11:51 PM
mooreofal
Joined Oct 22, '08
From spring
QUOTE (lagos @ Dec 15, 2008 - 11:29 AM) *
that does not matter. it all depends on the signal. is it the same 4-1 and 1-1 sensors that are in the 4afe 7afe? basically if you have a 4-1 sensor in your distributor you can use it like a points signal. the megasquirt just needs to be set up to accept a 5v signal and fire the coil directly. but the 95 and up 4afe and some 7afe have a crank mounted sensor i have one and im not going to use it just yet.
post Dec 16, 2008 - 12:56 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
looks good. coming along! yeah crank and cam sensors are both in the distro, sounds like like you have it all figured out so far.
post Dec 16, 2008 - 1:25 AM
There is more to it then that.
Our distributor has some noise issues with megasquirt.
Some people claim the issue can be fixed by adding vr signal conditioners, but I've yet to see someone who is actually running on the stock distributor without problems.
Easiest way is to get your own trigger wheel and upgrade to ford coil packs.
check this thread
http://mr2oc.com/showthread.php?t=283151
post Dec 16, 2008 - 7:37 AM
mooreofal
Joined Oct 22, '08
From spring
QUOTE (lagos @ Dec 16, 2008 - 2:25 AM) *
check this thread
check out msextra forums theres a couple guys with the 4afe distributor running on megasquirt. theres even a guy with a bt 20v that has a 4afe distributor in it. its not that hard to get rid of the signal noise. when i get home tonight ill try to dig up some links. but if you go to the diy autotune page and look up the 4age vast page its all done the same way as the 4a-7afe.
by the way your car looks awesome, and i didnt get a chance to look at the mr2 link because i didnt have time to register this mourning.
post Dec 16, 2008 - 7:57 PM
Let us know how it works out. If you manage to get it running, I'll buy a kit asap and set it up on my car.
post Dec 16, 2008 - 9:05 PM
mooreofal
Joined Oct 22, '08
From spring
will do. it will be a couple weeks till i get my pistons and i can put it together.
also. my 4afe block has a crank mounted 34-1 wheel and sensor if i have issue's with the 4-1 sensor signal than ill re-mod the board and use this sensor as an input.
Lo-Fi Version Time is now: September 1st, 2026 - 1:47 PM
