> help with my engine
post Dec 13, 2008 - 5:13 PM
Decalsondemand
Joined Nov 12, '08
From ohio
hi i am in the process of installing a 5sfe out of a 92 into my 94 gt!! everything seems to be fitting up fine besides changing a few sensors...the problem i have ran into is there is a sensor on the back of the block i believe by the number 3 cyl that doesnt exist on the 92 engine the is also one that twists in somewhere close to the dist i believe that the 92 doesnt have....should my car run without these? any help would be of use on this.... thanks
Replies (1 - 9)
post Dec 13, 2008 - 5:31 PM
frisp
Joined Jan 2, '08
From Scotland
Going off the top of my head here. The sensor @ No3 cylinder will be the knock sensor. Not sure about the other, haven't worked on a 5sfe.
I'm sure the others will be able to give more info, and correct me if I'm wrong. biggrin.gif
Regards
frisp
HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier
Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's
JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6
To be done....
Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads
post Dec 13, 2008 - 7:26 PM
Decalsondemand
Joined Nov 12, '08
From ohio
here is a picture of the other thing kind of a bad pic
post Dec 13, 2008 - 9:35 PM
frisp
Joined Jan 2, '08
From Scotland
I'll have a look when I get home, can't see pics on forums from work kindasad.gif
Regards
frisp
To be done....
post Dec 14, 2008 - 8:19 AM
Decalsondemand
Joined Nov 12, '08
From ohio
would i be able to plug in and use my ecu from my 92? are the plugs the same? would this eliminate probs or create more?
post Dec 14, 2008 - 8:36 AM
i told you using the older motor was a bad idea.
the first thing is it dont have a knock sensor.
you can screw the knock sensor into a bolt hole in the back of the block somewhere, it wont work too good, but at least you wont have a CEL.
that second one looks like an EGR temp sensor. did you use the 94 intake manifold?
if not, you have to.
and no, you cant use the 92 ecu in 94+ car.
post Dec 14, 2008 - 10:00 AM
trdproven
Joined Aug 2, '05
From Guam
Its best since on this situation to go forward, not backwards.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 14, 2008 - 10:52 AM
Decalsondemand
Joined Nov 12, '08
From ohio
i had to use this engine as i dont have the funds to buy a newer one...and the person that offerd to sell me one affordable backed out on me.....i will go change the intake manifold no biggie as long as i can get this going and have some transportation for now until i can get a better engine!! i have not changed the intake but i will go do that today while both engines are out....
post Dec 14, 2008 - 12:24 PM
QUOTE (Decalsondemand @ Dec 14, 2008 - 10:52 AM) *
take a GOOD hard look at the 2 engines, anything that looks even SLIGHTLY diffrent, swap over.
water necks, distributor, intake manifold, exhaust manifold, egr assebely (its attached to the intake manifold) all that stuff needs to be swaped from the 94 motor, along with the harness.
post Dec 14, 2008 - 1:13 PM
Decalsondemand
Joined Nov 12, '08
From ohio
ok i got everything swapped just waiting for my intake gasket to arrive
Lo-Fi Version Time is now: September 12th, 2026 - 11:17 AM
