> How much does a distributor, coil and plug wires sell in your area, Trying to source out this parts for lesser bucks...
post Dec 15, 2008 - 10:03 AM
Jeunesse
Joined Aug 21, '07
From Toronto
help...
And also, how hard is it to change these?
thanks guys.
This post has been edited by Jeunesse: Dec 15, 2008 - 10:05 AM
-Derick
"In hoc signo vinces." In this sign thou shalt conquer."
Gone but never forgotten....
Replies (1 - 4)
post Dec 15, 2008 - 10:51 AM
QUOTE (Jeunesse @ Dec 15, 2008 - 10:03 AM) *
help...
thanks guys.
im assuming your talking about a distributor CAP? rotor and wires?
you should be able to pick up everything @ your local toyota dealer for ~80$.
go to www.partznet.com, lookup the part you need, print out the page with the prices, and bring that to your local dealer, the should pirce match.
only tools you need is a good phillips head screwdriver, and or an 8mm socket for the distributor cap and rotor.
on a 1-10 scale, this stuff is a 2, very basic, especially if you use OEM parts, even the wires are numbered.
post Dec 15, 2008 - 11:33 AM
Jeunesse
Joined Aug 21, '07
From Toronto
Yep.... cause I need to do a tune up really really soon for my car is running stupid rich right now. I did change the O2 sensor couple of months back so I think that's not the problem.
Should I change the distibutor as well Manny?
-Derick
post Dec 15, 2008 - 11:40 AM
QUOTE (Jeunesse @ Dec 15, 2008 - 11:33 AM) *
no, do the cap, rotor, wires, and plugs...the distributor doesnt need to be replaced, unless its broken.
post Dec 15, 2008 - 11:44 AM
Jeunesse
Joined Aug 21, '07
From Toronto
wooohooooo.... thanks man. Is there anything else I need to know? Are these parts the same for the ST and GT?
This post has been edited by Jeunesse: Dec 15, 2008 - 11:53 AM
-Derick
Lo-Fi Version Time is now: May 30th, 2026 - 11:46 AM
