Dec 15, 2008 - 4:32 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Okay, so my motor 2nd gen 3sgte has been misfiring lately. I talked to Lagos about it and we thought that it would be the spark plug wires. I have NGK blue ones by the way and have been running it since my Swap back in June. It just started misfiring out of no where, but that isn't the issue now.
My car won't start. It will crank but won't start. So I pulled my spark plug wires and tested to see if I'm getting spark and NO dice. Then I pulled my coil wire going to the distributor cap and checked if I was getting spark and yes I was getting spark but a weak one. Either way that means that the coil is still good, no? Do I need a new dizzy? Ignitors rarely go bad so I don't want to replace a 300 dollar part just yet. I need help ASAP this is my DD. -------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Dec 15, 2008 - 5:37 PM
Okay, so my motor 2nd gen 3sgte has been misfiring lately. I talked to Lagos about it and we thought that it would be the spark plug wires. I have NGK blue ones by the way and have been running it since my Swap back in June. It just started misfiring out of no where, but that isn't the issue now. My car won't start. It will crank but won't start. So I pulled my spark plug wires and tested to see if I'm getting spark and NO dice. Then I pulled my coil wire going to the distributor cap and checked if I was getting spark and yes I was getting spark but a weak one. Either way that means that the coil is still good, no? Do I need a new dizzy? Ignitors rarely go bad so I don't want to replace a 300 dollar part just yet. I need help ASAP this is my DD. i think i have a spare coil and ignitor for a 2nd gen,...PM me, ill check around for them. -------------------- Former Team 5SFTE pro member ;)
Dec 15, 2008 - 10:09 PM
Enthusiast ![]() Joined Apr 27, '07 From Charlotte, NC Currently Offline Reputation: 2 (75%) |
sounds like what my car did a few weeks ago,
pull the distributor cap and see what it looks like in there. dizzy's aren't too expensive |
Dec 16, 2008 - 2:15 AM
yeah right!!! Money don't grow on tree around here. 170 is a lot to me. my cap and rotor is fine. Dizzy looks dirty, but it looks like it has never been replaced. I'm assuming it could be a weak coil. any way I will be at my buddies house checking to see if my coil is actually bad, by using it on his 3rd gen and to see if my dizzy is bad too. Now the igniter will be the culprit if both work good on his car.
Dec 16, 2008 - 5:45 AM
yeah right!!! Money don't grow on tree around here. 170 is a lot to me. my cap and rotor is fine. Dizzy looks dirty, but it looks like it has never been replaced. I'm assuming it could be a weak coil. any way I will be at my buddies house checking to see if my coil is actually bad, by using it on his 3rd gen and to see if my dizzy is bad too. Now the igniter will be the culprit if both work good on his car. do the bgb tests on the coil and ignitor, one of them is more than likely the issue -------------------- Former Team 5SFTE pro member ;)
Dec 16, 2008 - 9:12 AM
yeah right!!! Money don't grow on tree around here. 170 is a lot to me. my cap and rotor is fine. Dizzy looks dirty, but it looks like it has never been replaced. I'm assuming it could be a weak coil. any way I will be at my buddies house checking to see if my coil is actually bad, by using it on his 3rd gen and to see if my dizzy is bad too. Now the igniter will be the culprit if both work good on his car. do the bgb tests on the coil and ignitor, one of them is more than likely the issue just FYI, i found my spare coil and ignitor, the coil is actually not that bad new from toyota Item NumberMSRPCore PricePrice9091902175$105.94$0.00$80.51 COIL ASSY,IGNITION its the ignitor that will kill ya to buy new. Item NumberMSRPCore PricePrice8962112010$511.48$0.00$388.72 IGNITER let me know what the BGB tests show ya. -------------------- Former Team 5SFTE pro member ;)
Dec 16, 2008 - 10:22 PM
Thanks Manny, but I needed my car right away so I went to NAPA and picked up the coil for 46 bucks. Thanks to price matching.
| Lo-Fi Version | Time is now: July 30th, 2026 - 4:33 AM |
