Dec 15, 2008 - 11:20 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
Ok help !!
I was trying to install a short shifter took off the negative terminal on the batt. That was the night before. Together put everything back together. Music plays Dash lights come on. As i try start the car it dies. Now nothing turns on. What do i do? Jump start the car/batt again? -------------------- |
whatthe Help car wont start Dec 15, 2008 - 11:20 PM
Remy Before you try to jump start it try checking your ... Dec 15, 2008 - 11:22 PM
whatthe ^this is going to sound noob as hell but how and w... Dec 15, 2008 - 11:24 PM
garin did you test the battery? if you have a multimeter... Dec 15, 2008 - 11:31 PM
bccentaur3 So all the lights don't even come on now? Dec 15, 2008 - 11:32 PM
Remy Make sure they're not broken like that. Just c... Dec 15, 2008 - 11:33 PM
whatthe I tried to start it again, this time turned off th... Dec 15, 2008 - 11:41 PM
NGHTKD this happened with my mates 6th gen and it turned ... Dec 15, 2008 - 11:43 PM
whatthe Ok, all the fuses under the hood are good . . what... Dec 15, 2008 - 11:49 PM
Remy Yes now try to jumpstart it. Dec 15, 2008 - 11:56 PM
whatthe First try, struggled and failed. Second try Succes... Dec 16, 2008 - 12:06 AM
trd_420 if your headlights are dimm its the battery!... Dec 16, 2008 - 12:12 AM
legalkid86 if the car cannot maintain to stay on while on idl... Dec 16, 2008 - 12:23 AM
whatthe ok im back again. . .car started i went for a driv... Dec 16, 2008 - 12:28 AM
legalkid86 Its either you have a lose cable that comes direct... Dec 16, 2008 - 12:34 AM
PHLCELICA I've had that problem before. Next time try an... Dec 16, 2008 - 12:36 AM
whatthe Yeh when the car is on and im driving it doesnt di... Dec 16, 2008 - 12:38 AM
legalkid86 very rare the battery would be the problem, more t... Dec 16, 2008 - 12:39 AM
whatthe yeh i do hear a crank, what do you mean cable from... Dec 16, 2008 - 12:42 AM
legalkid86 its the positive cable that runs from the back of ... Dec 16, 2008 - 12:47 AM
azian_advanced one thing you should do is clean the battery termi... Dec 16, 2008 - 2:42 AM
bccentaur3 Get a voltmeter check your battery. It should be a... Dec 16, 2008 - 2:56 AM
Remy QUOTE (whatthe @ Dec 15, 2008 - 11:3... Dec 16, 2008 - 11:44 AM
RUNNIN-LOW well that has happen to me alot lately.. check you... Dec 16, 2008 - 12:12 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 20th, 2026 - 8:53 AM |
