> Help car wont start, Batt problem
post Dec 15, 2008 - 11:20 PM
whatthe
Joined Aug 13, '08
From Australia
Ok help !!
I was trying to install a short shifter took off the negative terminal on the batt. That was the night before. Together put everything back together. Music plays Dash lights come on. As i try start the car it dies. Now nothing turns on.
What do i do? Jump start the car/batt again?
- whatthe   Help car wont start   Dec 15, 2008 - 11:20 PM
- - Remy   Before you try to jump start it try checking your ...   Dec 15, 2008 - 11:22 PM
- - whatthe   ^this is going to sound noob as hell but how and w...   Dec 15, 2008 - 11:24 PM
- - garin   did you test the battery? if you have a multimeter...   Dec 15, 2008 - 11:31 PM
- - bccentaur3   So all the lights don't even come on now?   Dec 15, 2008 - 11:32 PM
- - Remy   Make sure they're not broken like that. Just c...   Dec 15, 2008 - 11:33 PM
- - whatthe   I tried to start it again, this time turned off th...   Dec 15, 2008 - 11:41 PM
- - NGHTKD   this happened with my mates 6th gen and it turned ...   Dec 15, 2008 - 11:43 PM
- - whatthe   Ok, all the fuses under the hood are good . . what...   Dec 15, 2008 - 11:49 PM
- - Remy   Yes now try to jumpstart it.   Dec 15, 2008 - 11:56 PM
- - whatthe   First try, struggled and failed. Second try Succes...   Dec 16, 2008 - 12:06 AM
- - trd_420   if your headlights are dimm its the battery!...   Dec 16, 2008 - 12:12 AM
- - legalkid86   if the car cannot maintain to stay on while on idl...   Dec 16, 2008 - 12:23 AM
- - whatthe   ok im back again. . .car started i went for a driv...   Dec 16, 2008 - 12:28 AM
- - legalkid86   Its either you have a lose cable that comes direct...   Dec 16, 2008 - 12:34 AM
- - PHLCELICA   I've had that problem before. Next time try an...   Dec 16, 2008 - 12:36 AM
- - whatthe   Yeh when the car is on and im driving it doesnt di...   Dec 16, 2008 - 12:38 AM
- - legalkid86   very rare the battery would be the problem, more t...   Dec 16, 2008 - 12:39 AM
- - whatthe   yeh i do hear a crank, what do you mean cable from...   Dec 16, 2008 - 12:42 AM
- - legalkid86   its the positive cable that runs from the back of ...   Dec 16, 2008 - 12:47 AM
- - azian_advanced   one thing you should do is clean the battery termi...   Dec 16, 2008 - 2:42 AM
- - bccentaur3   Get a voltmeter check your battery. It should be a...   Dec 16, 2008 - 2:56 AM
- - Remy   QUOTE (whatthe @ Dec 15, 2008 - 11:3...   Dec 16, 2008 - 11:44 AM
- - RUNNIN-LOW   well that has happen to me alot lately.. check you...   Dec 16, 2008 - 12:12 PM
Lo-Fi Version Time is now: September 20th, 2026 - 8:55 AM
