> Front Suspension Creaking over slow bumps???, What's causing this??
post Dec 18, 2008 - 7:33 AM
LTom
Joined Dec 18, '08
From Oxford, England
Do I just need to use some silicone lubricant to loosen up the bushes...or is there a more serios problem.
FYI I have a 1998 ST...stock suspension...the creaking is a rubbery creak....not a grindy-metally one.
Replies (1 - 6)
post Dec 18, 2008 - 9:03 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
I can't remember if the ball joints and what not are greasable. Get under there and check for grease fittings, if you find them, grease them. That should take care of the problem.
post Dec 18, 2008 - 9:43 AM
samir0189
Joined Mar 8, '08
From Orlando, Florida
I never checked if we have grease fittings, but even if we don't you can still grease them with a grease gun and this injector needle.
Its a tiny [way smaller than it looks in that pic] needle that goes through the rubber and makes such a small hole that its nearly impossible for the grease to come back out. biggrin.gif
My F/S Thread!
Ferdi says (11:29)
post Dec 18, 2008 - 9:22 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
hey samir0189, where do you get this thing from. I might need to use it for my front sway bar bushings. cause im having a real hard time taking the bushings out so that i can put silicone lub on them. Any suggestion on how to take them out. I know you need a 12mm socket and then there is a bolt that requires you to use a alloy wrench. but theres almost no space to work. I have st sway bars. i had my friend help me but i want to do it on my own
post Dec 18, 2008 - 9:59 PM
samir0189
Joined Mar 8, '08
I get it from Tractor Supply Company store locally. You need to have a grease gun and air compressor to use it though.
My F/S Thread!
Ferdi says (11:29)
post Dec 20, 2008 - 2:53 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (samir0189 @ Dec 18, 2008 - 9:59 PM) *
alright then i might just buy that. Well i guess i'm going to have ask my friend to help me with it.
post Dec 20, 2008 - 7:36 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
IIRC there are some zerk fittings under there somewhere, its the reason why I bought my grease gun. Its been a while since ive been under there but I saw them when i changed out my brake pads.
Lo-Fi Version Time is now: July 26th, 2026 - 12:20 PM
