> To pull (the engine) or not to pull (the engine). That is the question
post Dec 22, 2008 - 1:15 PM
robidunno
Joined Nov 6, '08
From San Antonio, TX
As I'm removing the tranny to install a new clutch, is it better to remove the engine to replace seals/gaskets? I presently have no hoist or engine stand, but can access one. I'm getting a gasket set from Toyota to button this thing back up but don't know what would be easier. I know that it's alot easier to work on the engine outside of the car, but is it worth the time to pull it for that?
This post has been edited by robidunno: Dec 22, 2008 - 2:16 PM
Rob C.
1994 Celica ST Coupe White 5 spd (temporarily)
1985 Celica Supra P Type Super White 5 spd
Replies (1 - 7)
post Dec 22, 2008 - 1:27 PM
D-Man
Joined Jan 18, '08
From Houston
Damn D-Man - most impressive.
post Dec 22, 2008 - 2:06 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
QUOTE (D-Man @ Dec 22, 2008 - 1:27 PM) *
HAAHAHA!!! laugh.gif but yeah anyways it works both ways you can pull the engine and do the head gakets and stuff or leave it in the car really up to u..i rather pull the whole engine..it makes life way easier..haha
post Dec 22, 2008 - 2:21 PM
robidunno
Joined Nov 6, '08
biggrin.gif I didn't even think about that when I titled the thread... Should be better now.
D-man, I'm assuming you're saying yes to being worth pulling the engine?
This post has been edited by robidunno: Dec 22, 2008 - 2:22 PM
Rob C.
post Dec 22, 2008 - 2:42 PM
D-Man
Joined Jan 18, '08
From Houston
Yes i am. Because these things can get tricky, depending on witch all ones you're changing. But if you're changing them ALL then it'd be easier than piecing out your engine from it's mount and replacing it all. And seeing as you're trying to get into the tranny as well; you'd might as well just pull the whole thing and be able to do what you've gotta do; rather than constantly hold yourself at uncomfortable positions, with little to no working room & light... plus trying to drop the tranny from under just so that you can disasemble the engine from the top as well? Might as well just pull the whole damn thing and get'r'done as they say. laugh.gif
So go ahead and:
Git'r'done
BTW: you're local Hi-Low or Pepboy's will rent you out a GOOD engine hoist for about $75.00.
And thanks for changing the name... I was about to have a field day on this thread tongue.gif
This post has been edited by D-Man: Dec 22, 2008 - 2:43 PM
post Dec 22, 2008 - 2:50 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
I'm confused. your doing a clutch, correct? what gaskets are you replacing?
post Dec 22, 2008 - 3:36 PM
Honestly ..pull your whole motor and do the cam seal, crank, rear main, timing belt, water pump, etc...
Its a hell of a lot better to do it all at once with the engine out, then to have to go back in there again in a year or so.
post Dec 22, 2008 - 6:38 PM
robidunno
Joined Nov 6, '08
Yes, I'm doing the clutch. Right now I feel lucky to have driven it from the driveway to the shop out back because it slips SOOO much. Probably a new flywheel at the same time because how bad it feels. I'll see when I take her apart. I'm planning on doing it all at the same time. Head, intake, exhaust, valve cover... gaskets, and any seals that I come in contact with. The timing belt and water pump too. The motor's got 200,000 miles right now, so we'll see what more she can do.
Rob C.
Lo-Fi Version Time is now: September 13th, 2026 - 9:29 AM
