Dec 26, 2008 - 10:48 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
Does anyone have any pics on how to install the TRD Front Extensions / Splitters?
Thanks!
This post has been edited by Jaws4God: Dec 27, 2008 - 11:51 PM -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Dec 27, 2008 - 10:48 PM
well here's how I did it:
Dec 27, 2008 - 10:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
see the screw hole in the first picture, inside the wheel well? screw it through there.... bondo that hole u put it the side. also 3m double sided adhesive tape = god.
-------------------- ![]() Kawi Love |
Dec 27, 2008 - 11:29 PM
see the screw hole in the first picture, inside the wheel well? screw it through there.. I saw that.. but where does it screw into? the only thing there is the plastic fender well -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Dec 27, 2008 - 11:41 PM
i just noticed thats the front...
u sure those are not REAR extensions? -------------------- ![]() Kawi Love |
Dec 27, 2008 - 11:46 PM
i just noticed thats the front... u sure those are not REAR extensions? gosh I hope not.. that would be embarrassing.. -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Dec 27, 2008 - 11:50 PM
I think i'm ok.. here's a pic of rear(left) and front(right)...
mine looked like the right side
Dec 28, 2008 - 12:51 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
well here's how I did it: ![]() ![]() BAD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! just use the bottom holes, they should line up with the existing holes. -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 28, 2008 - 1:17 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
do it that Hawaiian way!!!!TAPE FTW
hahahhah jon is gonna kill me ![]() jaws i have like 2 more if u need further reference This post has been edited by CelicaST_CALI: Dec 28, 2008 - 1:22 AM -------------------- BANNED. for life, you moron.
Dec 28, 2008 - 1:20 AM
Dec 28, 2008 - 2:29 AM
BAD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! just use the bottom holes, they should line up with the existing holes. The bottom holes did line up, but without support for the top it didn't sit flush with the bumper... -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Dec 28, 2008 - 4:36 AM
double sided tape or expoxy. depends how fixed you want the extensions to be
Dec 28, 2008 - 9:33 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 21, '08 From Naples, FL Currently Offline Reputation: 0 (0%) |
You actually drilled into the side of the bumper? Ouch...
Dec 28, 2008 - 10:00 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
The extension arent gonna sit exactly flush. Like everybody said. Double sided tap. Also there is like a 1/4 fold on the inside of the fender well. Thats where the screw goes. Just a little one like a wood screw or something similar on the upper portion of the extension and one to two on the lower portion. And DOUBLE SIDED TAPE. Better patch that hole up in the side. oh yeah. for the fender wells u don't need washer on the screws
-------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Dec 29, 2008 - 1:42 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
I only have the 2 main bolts to hold them and they sit flush, no tape, nothing more, but u have to use the largest washers u can fit!!!!!!!!
The middle screw is fine the one closer to the tire is too small, and the secret is..............don't be afraid to bend the bottom of your fender..i bent the tire side tab down towards the ground, and the bumper side up towards the engine bay...I've been fine like that for 5 months and they haven't flown off at high speed either.. (I used to use double sided tape before this and it just kept separating and stuff..) I didn't do this but what they mean about the other screw I believe is use a long thin wood screw through the fender plastic as it will help guide the splitter closer to the body...maybe toyota originally used a plastic push rivet like the ones found in the interior?? |
| Lo-Fi Version | Time is now: May 16th, 2026 - 1:52 AM |
