> HELP electrical nightmare?
post Dec 29, 2008 - 10:48 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
2 weeks ago I replaced my alternator; the car died outside Autozone, and it tested w/a bad diode. So I replaced it and I'm going along fine, but then last week the car starts acting up like the battery is bad. I had to jump it a few times. Nothing weird otherwise though.
I arrange to get a new battery, because the car is still funky. The battery light flashes at me if I rev the car up over 3k RPMs. Last night I pull into Safeway, and think Oh crap, I should back in in case I need a jump, but too late. Dead. Only this time, I CAN'T jump start it. Nothing will work. There's no click, no nothing whatsoever. Even leaving it hooked up to charge it a while doesn't work. When the car died, the check engine light and the oil light stayed on. No other indication of power but that. WHAT DOES THAT MEAN!?
Tonight I show up with a new battery, get it all hooked up, but still nothing. I have an alarm light that blinks, and it blinked normally until I did anything to the car. I could step on the brake pedal, or press in the clutch to start it, and the car goes back to dead again, w/the exception of the CEL and Oil lights being on. Oh, and I left the negative disconnected overnight because it just seemed like a good idea.
So the car still sits. When I reconnect the negative terminal to the new battery, I can hear something clicking under the hood that comes from the relay boxes, both by the alternator and the one on the driver's side. Every time I reconnect the neg it makes that sound, and then the alarm light resumes blinking. But doing anything else, even trying to turn on the dome light, will make it go dead again. I've checked the fuses and they all look fine. Do I have a bad ground somewhere? HELP!
- GriffGirl   HELP electrical nightmare?   Dec 29, 2008 - 10:48 PM
- - lagos   check your alternator battery wire, as well as the...   Dec 29, 2008 - 11:27 PM
- - stephen_lee   check grounds. My integra did something very simil...   Dec 30, 2008 - 12:01 AM
- - WWSideWinder   Hi GriffGirl On my Car 3Fe motor i have 3 ground ...   Dec 30, 2008 - 4:59 AM
- - Dr_Tweak   Definitely sounds like a grounding issue, or possi...   Dec 30, 2008 - 8:44 AM
- - DEATH   Just add extra grounds from the alt bracket to the...   Dec 30, 2008 - 9:21 AM
- - GriffGirl   Well I googled it too and it looks like it has som...   Dec 30, 2008 - 10:49 AM
- - DEATH   If you're battery has dual posts you can very ...   Dec 30, 2008 - 10:53 AM
- - D-Man   You DO infact have the new battery in it, yeah? D...   Dec 30, 2008 - 11:05 AM
- - GriffGirl   What you said about funky wiring makes sense, but ...   Dec 30, 2008 - 6:23 PM
- - Batman722   bad alternator (voltage regulator)   Dec 30, 2008 - 11:13 PM
- - GriffGirl   Bad ground wire from block - see pix below: jerr...   Dec 31, 2008 - 11:33 AM
- - DEATH   Yup - that's what I thought. I'd just do w...   Dec 31, 2008 - 11:39 AM
|- - D-Man   QUOTE (DEATH @ Dec 31, 2008 - 10:39 ...   Dec 31, 2008 - 11:42 AM
||- - DEATH   QUOTE (D-Man @ Dec 31, 2008 - 10...   Dec 31, 2008 - 11:49 AM
|- - CelicaST_CALI   QUOTE (DEATH @ Dec 31, 2008 - 8:39 A...   Jan 1, 2009 - 3:01 PM
- - Dr_Tweak   What I think is pretty cool is that the first thin...   Dec 31, 2008 - 12:37 PM
|- - DEATH   QUOTE (Dr_Tweak @ Dec 31, 2008 - 11...   Dec 31, 2008 - 12:51 PM
- - GriffGirl   Awesome props, thanks guys! But I still need t...   Dec 31, 2008 - 1:35 PM
|- - D-Man   QUOTE (GriffGirl @ Dec 31, 2008 - 12...   Dec 31, 2008 - 3:26 PM
- - stephen_lee   That plastic connector is just a "disconnect...   Dec 31, 2008 - 3:21 PM
- - WWSideWinder   Hi GriffGirl Have a look at my Curren Updates to ...   Jan 1, 2009 - 2:01 AM
Lo-Fi Version Time is now: August 27th, 2026 - 12:16 PM
