> loss of power, engine is louder, has less power than before
post Jan 5, 2009 - 1:07 AM
celicamike
Joined Dec 26, '05
From So Cal
Hey guys, I did a search but didn't find anything useful. I've noticed that my '94 GT has been kind of sluggish recently. It takes forever to accelerate, particularly when going uphill, and it kind of sputters/hesitates when I wind it over 3500 RPM. I've also observed that the engine becomes much louder when I put it under a load, almost like a exhaust leak. Anyway, the car idles fine and there is nothing unusual when cruising once I get up to speed. Have any of you experienced this or have any idea what the problem is? I don't have any apparent vacuum leaks, and the compression was great. The car is pretty old though, with 213,000 miles. I'm thinking that I might need new plug wires and distributor cap and rotor, since the ones I have now are presumably the originals. What do you guys think, could this be the answer to my problem? I appreciate your help. Thanks.
- celicamike   loss of power   Jan 5, 2009 - 1:07 AM
- - bccentaur3   Change your o2 sensor, spark plugs/wires, cap, rot...   Jan 5, 2009 - 1:25 AM
- - terbear4god4life   iv got the same problum... my drive axles bad im h...   Jan 5, 2009 - 2:21 AM
- - trdproven   Not sure if I am making any sense but maybe your e...   Jan 5, 2009 - 9:16 AM
- - elastikman   Humm....Busted clutch ??   Jan 5, 2009 - 9:51 AM
- - terbear4god4life   QUOTE (elastikman @ Jan 5, 2009 - 10...   Jan 5, 2009 - 9:57 AM
- - bccentaur3   To find out if your clutch is bad you can put it i...   Jan 5, 2009 - 10:43 AM
- - Remy   Maybe you have a exhaust manifold leak you lose al...   Jan 5, 2009 - 11:53 AM
- - celicamike   Thanks guys, I'll look in to all of the above....   Jan 5, 2009 - 1:51 PM
- - terbear4god4life   QUOTE (bccentaur3 @ Jan 5, 2009 - 11...   Jan 5, 2009 - 10:52 PM
- - terbear4god4life   hello?   Jan 12, 2009 - 4:49 PM
- - silver6gc   QUOTE bccentaur3 Posted Jan 5, 2009 - 11:43 AM ...   Jan 12, 2009 - 6:29 PM
- - celicamike   Ok guys, I have an update on my situation. It tur...   Jan 19, 2009 - 1:25 PM
- - silver6gc   i don't know where you're from that you th...   Jan 19, 2009 - 6:37 PM
- - Batman722   zip tie the hose back on the EGR and change your 0...   Jan 19, 2009 - 6:52 PM
- - nik   im having the same problem in my GT i have zip ti...   Jan 19, 2009 - 7:03 PM
- - Starcelica101   Throttle position sensor problem, It just doesn...   Jun 23, 2009 - 12:39 AM
- - Bitter   uh clogged cat?   Jun 23, 2009 - 7:22 AM
|- - presure2   QUOTE (Bitter @ Jun 23, 2009 - 7:22 ...   Jun 23, 2009 - 7:26 AM
- - Hanyo   get a vaccuum gauge and test your engines vaccuum ...   Jun 23, 2009 - 7:45 AM
- - Bitter   or just have someone feel the exhaust flow while y...   Jun 23, 2009 - 9:42 PM
Lo-Fi Version Time is now: August 31st, 2026 - 12:46 AM
