> Drivers Side Speakers
post Jan 15, 2009 - 8:13 PM
Sk8tmx
Joined Jan 13, '09
From Maryland
My drivers side front speakers are out and i cant figure out why. I unplugged them and plugged them back in to check to see if it was a bad connection. That didnt work kindasad.gif. Could anyone help me?
post Jan 16, 2009 - 12:32 AM
richee3
Joined Jun 29, '08
From Denver
Probably a blown speaker. My car came with a blown driver's side speaker, and it didn't even try to work. I have a factory amp, and even still, when I pulled the speaker out, it was very clearly labeled on the back "TOYOTA 15 watt max." So if you've got an aftermarket head unit and you've cranked it up, it's a pretty safe bet that you fried your speaker.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 18, 2009 - 10:26 PM
costa
Joined Nov 6, '08
From locust grove, va
when i bought my car, i had the exact same problem. i had a bad factory stereo and replaced it with an aftermarket one and works fine now. good luck.
post Feb 9, 2009 - 6:06 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
I am still browsing for answers but I stumbled on to this post . I have a front passenger 8 inch speaker out and I was wondering what kind is it. Also what kind will replace it. Where did you get it (I cannot find one anywhere)and what size did you use. Thanks anyways found that guide to use the old speaker as a adapter. Thanks for that one.
Rv
Thanks in advance.
97 celica gt
This post has been edited by xrav22: Feb 9, 2009 - 6:43 PM
Lo-Fi Version Time is now: August 26th, 2026 - 1:43 PM
