> How To – Mounting Bonnet Struts, Done on a GT4 but same principle for ST and GT
post Jan 16, 2009 - 10:31 AM
3TST
Joined Sep 27, '02
From UK
Tools:
    12mm socket
    10mm socket
    10mm spanner
    Screwdriver
Time:@20-30 minutes
Here is the package I received.
Lift bonnet and use the bonnet stay to keep it up.
Start at the right side of the engine bay (as you face the engine from in front of the car).
Although instructions were provided, I found it easier by doing the following:
Procedure:
    1. Remove the retaining clip from the bonnet strut
    2. Attach the replacement bolt/pivot to the bonnet strut
    3. Replace the retaining clip
    Note: It’s a lot easier doing it this way because, once mounted, you will not be able to get that clip in.
    4. Undo the bolt in the wing that holds the rubber bonnet stop (10mm socket)
    5. Place the 2 washers (supplied) into position and then screw the bolt/pivot into position (10mm spanner)
    Note: Be careful not to strip the thread, it’s a little fiddly so just take your time and be patient
    6. Remove the retaining clip from the other end of the bonnet strut
    7. Attach the replacement plate/pivot to the bonnet strut
    8. Replace the retaining clip
    9. Remove the upper bolt of the bonnet hinge (12mm socket)
    10. Place the plate/pivot (not marked – see note below) into position and using the original bolt secure in place (12mm socket). You may need to lift and support the bonnet in order for the original bolt to locate properly.
    Note: Make sure that you have the right plate/pivot for that side. One plate/pivot had a sticker on it marked ‘R’, the other had no sticker or marking. The ‘R’ refers to the right BUT is as you sit in the car looking forward.
    The following picture shows one reason why I attached the plate/pivot to the strut first.
    11.That’s one side done.
    11. Repeat steps 1 – 10 for the other side.
    Note: The only difference I found was that I had to remove the washer jet tube located by the bonnet hinge.
    13. Once you have done both sides, you can remove the bonnet stay. It’s retained in the slam panel by a round plastic clip.
    • Manoeuvre the stay towards you
    • Wiggle it around a bit and it should easily pop out, leaving the round plastic clip in the slam panel
    • Remove the plastic clip by easing it out with a screwdriver.
This post has been edited by 3TST: Jan 17, 2009 - 2:05 PM
- 3TST   How To – Mounting Bonnet Struts   Jan 16, 2009 - 10:31 AM
- - zero07   Awesome write-up! Sticky this! I think alo...   Jan 16, 2009 - 2:36 PM
- - BloodyStupidDavey   It is a nice kit and works well, but the 'stai...   Jan 16, 2009 - 5:30 PM
- - Batman722   I've heard that the bonnet struts are very pow...   Jan 16, 2009 - 10:44 PM
|- - malpaso   QUOTE (Batman722 @ Jan 17, 2009 - 4...   Jan 17, 2009 - 1:16 AM
|- - BloodyStupidDavey   QUOTE (Batman722 @ Jan 17, 2009 - 3...   Jan 17, 2009 - 12:45 PM
- - lagos   I've been wanting these for a while now. Where...   Jan 16, 2009 - 11:35 PM
- - 97celiman   is this an ebay deal or something else or better ...   Jan 17, 2009 - 2:04 AM
- - celica3000   my next upgrade thanks to share   Jan 17, 2009 - 1:23 PM
- - 3TST   QUOTE I've heard that the bonnet struts are ve...   Jan 17, 2009 - 2:00 PM
- - celica3000   3TST THE HOOD WITH THESSE STRUTS YOU CAN CLOSE THE...   Jan 26, 2009 - 2:59 PM
- - petna   It would appear everyone is following in my footst...   Jan 26, 2009 - 6:06 PM
- - celica3000   arrive and installing nice mod thanks to share   Feb 1, 2009 - 6:35 AM
- - 97celiman   so im in the process of doing this and the strut d...   Mar 30, 2009 - 4:19 PM
- - jimmykay   When I put mine in they were a little long too. I...   Mar 31, 2009 - 10:45 AM
- - ZGear   Here's the specs for the hood dampers for thos...   Mar 31, 2009 - 4:54 PM
- - 97celiman   ya i got it all thats what i had to do was lift th...   Apr 1, 2009 - 4:51 PM
- - Artega   What's everyone's review on these after in...   Sep 23, 2009 - 6:16 PM
- - ZGear   My car's been in the rain a few times....haven...   Sep 23, 2009 - 7:35 PM
- - njccmd2002   keep em well oiled or dry. as the corrosion may c...   Sep 23, 2009 - 8:56 PM
- - trdproven   There is something definitely wrong with mine. Fi...   Sep 28, 2009 - 4:04 AM
- - whatthe   Post pics. I received and installed mine last week...   Sep 28, 2009 - 4:37 AM
- - trdproven   ok, imagine the bracket curves like an L and curve...   Sep 28, 2009 - 4:54 AM
- - trdproven   I just wanted to bring this up before I start hack...   Sep 29, 2009 - 12:38 AM
- - jimmykay   pics could help. If needed, I could take some bet...   Sep 29, 2009 - 10:32 AM
- - Artega   Got mine in the mail today Will install them over ...   Oct 8, 2009 - 12:03 PM
- - trdproven   i believe this fitment will be fine with the dry o...   Oct 14, 2009 - 5:55 AM
- - chacha   my struts don't move up and down...any help wi...   Mar 26, 2010 - 9:09 PM
- - ajmorris1977   QUOTE (3TST @ Jan 16, 2009 - 11:31 A...   Mar 28, 2010 - 2:56 PM
- - dans_st   ^^^^^ I also want to know, I cannot find them anyw...   Jun 9, 2010 - 1:54 AM
- - Smiley   call me dumb but what does this actually do for th...   Jun 14, 2010 - 5:08 AM
|- - schmooot   QUOTE (Smiley @ Jun 14, 2010 - 3:08 ...   Jun 14, 2010 - 5:32 PM
- - yellowchinaman   I dont see why you need to be so careful with carb...   Jun 15, 2010 - 2:36 PM
- - Droptop93   Wonder if these will work for other gen celicas......   Sep 4, 2011 - 4:50 PM
- - WALKER   Thanks to your awesome write up I was able to inst...   Aug 5, 2013 - 1:26 AM
Lo-Fi Version Time is now: August 2nd, 2026 - 9:21 AM
