> How to tell if wheel bearing or ball joint is bad?, Updated!
post Jan 22, 2009 - 12:27 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
There are bad, evil, rubbing/grinding noises (sounds dirty heh heh) coming from my rear passenger wheel. Actually it sounds like the backing plate is rubbing against the rotor, but I'm pretty certain that's not what's going on. The sound is definitely related to the rotation of the wheel; it's louder when I go slower too although that could just be because there's less road noise to drown out the sound. The noise sounds not unlike when brake pads are completely worn and it's metal on metal - it's that grinding noise, not a squealing or high pitched noise at all. It's really loud from the driver's side though, I can only imagine what it sounds like outside the car!
I'm leaning toward bad wheel bearing but I wanted to check with you guys first to get some tips and ideas before I go buying the wrong part.
This post has been edited by GriffGirl: Feb 2, 2009 - 12:11 PM
- GriffGirl   How to tell if wheel bearing or ball joint is bad?   Jan 22, 2009 - 12:27 PM
- - tysst202   could be a bearing but it would make whirring nois...   Jan 22, 2009 - 5:33 PM
- - Salica   thats funny I have the same noise coming from my p...   Jan 23, 2009 - 3:43 AM
|- - LewFX   QUOTE (Salica @ Jan 23, 2009 - 1:43 ...   Jan 23, 2009 - 11:40 AM
|- - GriffGirl   QUOTE (LewFX @ Jan 23, 2009 - 8:40 A...   Jan 30, 2009 - 11:12 AM
- - Lil-Joe101   I have a weird noise too. On both sides. It sounds...   Jan 23, 2009 - 6:28 AM
- - jimmykay   IIRC if its a wheel bearing, then there should be ...   Jan 23, 2009 - 9:01 AM
- - GriffGirl   I will check for wheel play when I get it out to t...   Jan 23, 2009 - 11:20 AM
- - relyks95gt   this happends to all celicas!!! and we...   Jan 23, 2009 - 11:57 AM
|- - lingham   QUOTE (relyks95gt @ Jan 23, 2009 - 11...   Feb 24, 2011 - 12:05 PM
- - LewFX   id try the pencil to the rotor test...have someone...   Jan 30, 2009 - 2:04 PM
- - GriffGirl   I'll try that... it's not just the backing...   Jan 30, 2009 - 2:08 PM
- - LewFX   a broken end link would make popping sounds, might...   Jan 30, 2009 - 2:59 PM
|- - GriffGirl   QUOTE (LewFX @ Jan 30, 2009 - 11:59 ...   Jan 30, 2009 - 4:00 PM
|- - richee3   QUOTE (GriffGirl @ Jan 30, 2009 - 4...   Jan 31, 2009 - 12:05 PM
- - richee3   When I swapped my suspension out, I had to cut my ...   Jan 30, 2009 - 3:13 PM
- - GriffGirl   Hey- How many sway bar bushings does the car use? ...   Jan 30, 2009 - 4:22 PM
- - LewFX   2 in the rear, 2 in the front, fronts a pain...rea...   Jan 30, 2009 - 4:49 PM
- - trdproven   rears are indeed easier. never changed endlinks i...   Jan 30, 2009 - 5:22 PM
- - presure2   defiently sounds like a wheelbearing issue to me g...   Jan 31, 2009 - 10:19 AM
- - trdproven   If worse case scenario you have to drill which I r...   Feb 1, 2009 - 11:48 AM
- - GriffGirl   On topic: it was the damn emergency break. The spr...   Feb 2, 2009 - 12:10 PM
|- - richee3   QUOTE (GriffGirl @ Feb 2, 2009 - 1:1...   Feb 2, 2009 - 10:47 PM
- - trdproven   I'm about to put on my coilovers, wanna get my...   Feb 2, 2009 - 3:51 PM
- - GriffGirl   I know!!! I totally need to take pix -...   Feb 2, 2009 - 3:57 PM
- - trdproven   I truly believe these springs are awesome great fe...   Feb 2, 2009 - 7:03 PM
- - GriffGirl   I bet they are, but I don't wanna go back and ...   Feb 2, 2009 - 7:11 PM
- - Batman722   the same thing happen on my ST, I as gonna post ab...   Feb 2, 2009 - 9:55 PM
- - GriffGirl   Hub assembly bolt: $3.12 E-brake shoe: ...   Feb 4, 2009 - 12:26 PM
- - LewFX   been there, done that, and wrote a book   Feb 4, 2009 - 12:36 PM
- - _john_   You'd be surprised how many times those rattle...   Feb 26, 2011 - 7:32 PM
|- - lingham   QUOTE (_john_ @ Feb 26, 2011 - 7:32 ...   Feb 27, 2011 - 10:18 AM
- - skogs   Hi! I've got EXACTLY the same noise you ha...   Jul 25, 2011 - 3:30 AM
Lo-Fi Version Time is now: August 27th, 2026 - 3:12 AM
