Jan 28, 2009 - 2:28 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
Hey everyone,
My celi's always had a leak for as long as i can remember, but just one or two drops, nothing major. now... ![]() I have some pics of underneath the car, the leak is more passenger side on the ground. ALOT of oil is settled on this thing ![]() And the whole backside of the engine block appears shiny. (doesn't look shiny in pics though..) ![]() And this is the oil pan, it appears to be really oily, but idk if thats cause the oil settled there or if it originated fromthere. ![]() Any ideas? I can take more pics if need be. THANKS everyone! -------------------- ◊◊◊ My F/S Thread! ◊◊◊
samir0189 Engine Oil leak, with pictures. Jan 28, 2009 - 2:28 PM
Smaay i had the same problem, i ended up pulling the eng... Jan 28, 2009 - 2:34 PM
samir0189 QUOTE (Smaay @ Jan 28, 2009 - 3:34 P... Jan 28, 2009 - 2:40 PM
hatchy_gt-s Your pan could be leaking, but its not the only sp... Jan 28, 2009 - 2:40 PM
samir0189 i had cleaned it once to try that but then i had t... Jan 28, 2009 - 2:47 PM
nik valve cover gasket
and oil pan gasket
replace bot... Jan 28, 2009 - 2:53 PM
hatchy_gt-s ok so ya, well because the engine sits at a slant ... Jan 28, 2009 - 2:58 PM
samir0189 QUOTE (hatchy_gt-s @ Jan 28, 2009 ... Jan 28, 2009 - 3:06 PM
lagos could be the power steering pump. Jan 28, 2009 - 3:26 PM
samir0189 QUOTE (lagos @ Jan 28, 2009 - 4:26 P... Jan 28, 2009 - 3:35 PM
blu94gt QUOTE (samir0189 @ Jan 28, 2009 - 2... Jan 28, 2009 - 4:55 PM
Galcobar I had a leak covering the same areas -- check your... Jan 28, 2009 - 4:55 PM
samir0189 Well I've decided i'm gonna start off with... Jan 28, 2009 - 5:59 PM
Tigawoods oil pan isnt as hard as it seems. it takes time to... Jan 29, 2009 - 9:16 AM
samir0189 QUOTE (Tigawoods @ Jan 29, 2009 - 9... Jan 29, 2009 - 7:34 PM
silver6gc If youre timing belt is due in 3k then wait to do ... Jan 30, 2009 - 9:01 PM
samir0189 QUOTE (silver6gc @ Jan 30, 2009 - 10... Jan 30, 2009 - 10:45 PM
silver6gc QUOTE samir0189 Posted Yesterday, 11:45 PM
QUOT... Jan 31, 2009 - 5:18 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 4th, 2026 - 10:03 AM |
