Jan 31, 2009 - 8:21 AM
hey guys, as most of you know, i've been running a ACT stage 1 5sfe clutch since i swapped in arts motor back in the day, it has performed great for me over the past few years, with no issues, however, its starting to get some miles on it, and since i have been over the torque rating pretty much since the day i turboed, i cant expect it to last forever.
the problem begins with the fact that even the higher rated ACT clutches (and most 5s clutches for that matter) is that theyre only rated for 350ftlbs at the flywheel, and with 275ftlbs at the wheels, im pretty close to being over even THAT rating. so after a bit of research, i came up with this info. the 3sgte friction surface area is 236mm, the 5s is 225mm. the stock 185 flywheel will not bolt to a 5sfe crank, without elongating the bolt holes a fraction of an inch. guys who build strokers with the 5s crank run into this problem. the solution can be had in a few ways, either elongate the bolt holes on the 185 flywheel, or use a st-165 flywheel, which will bolt to the 5s crank, however the friction surface is 225mm, like the 5s, which i am trying to get away from. the fidanza light weight flyhweel for the 3sgte has elongated bolt holes from the factory, specificly for the stroker guys, who use the 5s crank. SO, what i am going to do, is use the fidanza 3s LW flywheel, 3sgte pressure plate and disk, and the disk will have the s54 spline count. ACT makes a disk for just this application, and has a part # available for it. here is a list of the parts that are needed, this list will work for 5sfte guys that are looking for 300+ftlbs at the wheels, as well as 3sgte swap guys that want to use the S54 (stock GT) transmission. it is a 6 puck, sprung hub disk, with theyre heavy duty pressure plate, rated at 499 ftlbs. at the flywheel. (theyre street disk is rated for 350ftlbs, they dont do that with the 5s spline) for the 5sfte and 5s based stroker guys, you need a st-165 flywheel, or fidanza lightweight flywheel for the 3sgte (swap guys, the flywheel is an option) ACT pressure plate PT # TO23 ACT 6 puck sprung disk PT# 6236216 i always recommend a OEM throwout bearing, but the ACT PT# is ACT throw out bearing PT# RB442 ACT alignment tool PT# AT17 ill post pics of the flywheel when it comes in, it should be here monday, for now, here are a couple of pics of the clutch setup (this is jims clutch, but it is the same disk and pressure plate, just diffrent spline count.) ![]() ignore the spec disk, ill edit in an actual pic of my disk when it gets here. ![]() woot for 500ftlbs worth of clutch! -------------------- Former Team 5SFTE pro member ;)
presure2 3sgte clutch kit on a 5sfte???? Jan 31, 2009 - 8:21 AM
lagos I think you would be just fine with a normal 5sfe... Jan 31, 2009 - 11:04 AM
presure2 QUOTE (lagos @ Jan 31, 2009 - 11:04 ... Jan 31, 2009 - 11:39 AM
lagos I dig. Jan 31, 2009 - 12:15 PM
Smaay yeah i could have told you this, i have the ST165 ... Feb 1, 2009 - 11:27 AM
presure2 QUOTE (Smaay @ Feb 1, 2009 - 11:27 A... Feb 1, 2009 - 2:14 PM
trdproven QUOTE (presure2 @ Feb 1, 2009 - 2:14... Feb 2, 2009 - 10:27 AM
trdproven I have an st185 3sgte lightweight flywheel in mine... Feb 1, 2009 - 11:34 AM
Dr_Tweak QUOTE (trdproven @ Feb 1, 2009 - 11... Feb 2, 2009 - 1:58 PM
Smaay good idea, ill hit up southbend and get part #s Feb 1, 2009 - 5:21 PM
presure2 WOOT flywheel came in just now!
got a great de... Feb 2, 2009 - 12:30 PM
Smaay actually newcelica.org for the 7th gen is very inf... Feb 2, 2009 - 5:30 PM
Red_T_swiftcam So other than Gear Ratios, why would you switch to... Feb 17, 2009 - 11:12 AM
presure2 i dont know that the s54 can handle 500ftlbs...i c... Feb 17, 2009 - 11:21 AM
presure2 so the competition clutch stage 4 hybrid clutch ki... Feb 21, 2009 - 10:37 AM
Dragondog QUOTE (presure2 @ Feb 21, 2009 - 4:3... Mar 10, 2009 - 5:10 AM
Smaay sexy, keep the pics coming Feb 22, 2009 - 1:16 PM
presure2 i got it from drtweak here on the board. http://ww... Mar 10, 2009 - 7:35 AM
trdproven Manny - I have a LW flywheel from an st185 and use... Mar 10, 2009 - 7:45 AM
presure2 QUOTE (trdproven @ Mar 10, 2009 - 7... Mar 10, 2009 - 7:51 AM
presure2 hey guys, back for an update on the competition cl... Jul 24, 2009 - 7:18 AM
Dr_Tweak QUOTE (presure2 @ Jul 24, 2009 - 8:1... Jul 30, 2009 - 9:43 PM
presure2 QUOTE (Dr_Tweak @ Jul 30, 2009 - 9:4... Jul 31, 2009 - 5:26 AM
trdproven Would it be a big problem though? I'm sure mi... Jul 24, 2009 - 10:52 AM
presure2 QUOTE (trdproven @ Jul 24, 2009 - 10... Jul 25, 2009 - 5:57 AM
trdproven That sucks, i'll find out when I change my clu... Jul 25, 2009 - 9:24 AM
presure2 QUOTE (trdproven @ Jul 25, 2009 - 9... Jul 25, 2009 - 9:33 AM
jjbenzo So if I have a 98 GT, swap in a 3rd gen. 3SGTE eng... Jul 27, 2009 - 5:33 PM
trdproven use the 3sgte clutch set up and the 5s spline on t... Jul 27, 2009 - 5:39 PM
lagos interesting that the act clutch uses 4 big springs... Jul 31, 2009 - 2:16 AM
Dr_Tweak Hey, I just came to check on this thread and it lo... Aug 5, 2009 - 10:29 AM
presure2 QUOTE (Dr_Tweak @ Aug 5, 2009 - 10:2... Aug 5, 2009 - 4:23 PM
Cuttyman9 I smoked the s53 in my car, so in the last week I ... Apr 20, 2013 - 11:00 AM
Smaay im confused, does the S53 and S54 have different s... Apr 29, 2013 - 3:33 PM
celica95-95 on a quick note i order the same CC clutch from tw... Apr 29, 2013 - 10:50 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 6:40 PM |
