Feb 4, 2009 - 5:49 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 22, '03 From Tracadie-Sheila, NB (Canada) Currently Offline Reputation: 14 (100%) |
Hi everyone,
are ABS sensors from Celicas with Superstrut suspension the same than standard suspension ABS sensors i finally found one ....just wonder if my car will take it also, 1rsttoyotaparts.com is listing those sensors as 94-95 and 96-99...is there a real difference? TIA |
Feb 4, 2009 - 5:54 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
im not too sure, but i reckon.
the 205 ones are the same as the camry ones of about the same year, duno what the chassis code is sv41 or something prob, the roudy shape ones. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
Feb 4, 2009 - 11:11 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
according to toyodiy.com, ST202 and ST205 celicas share the same front abs sensors... but the rears have different part numbers (more likely different because of the AWD i suppose).
also ST204 celicas have a different part numbers than the ST202/ST205s and 25% more expensive but there's still a chance that they could still be the same part but just have different part numbers. also 1994-1995 abs sensors are identical to1996-1999 celicas. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Feb 5, 2009 - 8:12 AM
according to toyodiy.com, ST202 and ST205 celicas share the same front abs sensors... but the rears have different part numbers (more likely different because of the AWD i suppose). also ST204 celicas have a different part numbers than the ST202/ST205s and 25% more expensive but there's still a chance that they could still be the same part but just have different part numbers. also 1994-1995 abs sensors are identical to1996-1999 celicas. thanx for the reply buddy are you sure about the 96-99 thing? here's the 1rsttoyotaparts info i got through their part database: -Front speed sensor, celica, right 1995 $172.51 Brakes - Anti-lock brakes - Front speed sensor -Front speed sensor, celica, right 96-99 $165.16 Brakes - Anti-lock brakes - Front speed sensor can they be the same but just different prices? |
Feb 5, 2009 - 8:50 AM
the Toyota EPC shows North American liftback celicas from 1994-1995 share the same part numbers as the 1996-1999.
then after checking this from my parts manual, it shows the 1994-95 having different part numbers as the 96-99s. with that said there's really no other way to confirm which of these is correct but i'm willing to bet the are the same. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:08 AM |
