> Reverse light LED's?, Has anyone done this?
post Feb 10, 2009 - 4:17 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Has anyone changed teh reverse lights in there tails to LEDs? How diffcult is it, what exactly do you have to do to change the reverse lights?
My Celica!
post Feb 13, 2009 - 1:58 PM
richee3
Joined Jun 29, '08
From Denver
Changing them out wouldn't be hard at all. It's the same as replacing the bulb. You just take the trim in your trunk out, then you'll see a few nuts that hold the tail lights in place. After that, it's pretty self-explanatory. As far as how bright it would be, I don't know. I would say it would be bright, but not as evenly spread as the bulbs you have now. It would be more like a flashlight pointing out in one direction than the even lighting all around like you currently have.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 13, 2009 - 4:22 PM
joehernandez
Joined Aug 5, '06
From San Luis AZ
there was someone who was trying to do that....
but he was doing the entire thing not only the reverse light.
it did looked excellent though. but for that you need a circuit board and some electronic knowledge.
post Feb 13, 2009 - 4:29 PM
bmj67
Joined Oct 23, '08
Culpable did a full led array for the taillights
post Feb 14, 2009 - 10:07 PM
92-gt
Joined Jan 22, '09
From Bremen
It should be plug and play for everything except the turn signals. FOr those you will need a resistor. I know some bulbs come with a resistor already, but they are a little pricey. Check out superbrightled.com
Lo-Fi Version Time is now: May 20th, 2026 - 10:26 AM
