> WTF is this thing? (Under drivers seat)
post Feb 15, 2009 - 12:22 AM
korban
Joined Feb 5, '09
From New Zealand
Pulled my front seat out the other day to install some wiring under the carpet, and found a 1 yen coin! A good reminder that my car is a Jap Import.
Also... there was this plastic box with a metal bottom that slides into a bracket, it also has a velcro strap to hold it down. Any ideas?
post Feb 15, 2009 - 12:32 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
oh NOOOOOOOO!!!! Thats a bomb! Could be an alarm?
94 Celica gt white (sold)
post Feb 15, 2009 - 12:43 AM
korban
Joined Feb 5, '09
From New Zealand
I don't think I have a factory alarm, and it's definitely OEM wiring. I thought it could be an amp but I only have the 4 speaker system, and everything appears to be run directly from the headunit.
post Feb 15, 2009 - 1:24 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i think ita an amp. but find the part number on it and look it up
post Feb 15, 2009 - 1:46 PM
jack-p
Joined Oct 4, '08
From cornwall
Is it the factory fitted security system that works of the central locking
i asked the same question on CCUK a couple of weeks back http://www.celica-club.co.uk/forum/index.php?showtopic=78477
post Feb 15, 2009 - 1:49 PM
Seven1Six
Joined Jul 29, '08
From Buffalo
The black box lol
post Feb 15, 2009 - 2:08 PM
WWSideWinder
Joined Oct 2, '08
From New Zealand
Factory Fitted Alarm (Maby) but is definatly the central locking unit to work with the Factory Key.
I found this in my car as well took it out and the remote on the key stopeed working. I use a aftermarket alarm now but I have left this in plave so I can get into my car if the new alarm fails. LOL
When are we gonna see some pic's of you car???
WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
~ signature made by jaws4god ~
Have a look at my thread for updates on my progress.
"http://www.6gc.net/forums/index.php?showtopic=63338&hl=0"
post Feb 15, 2009 - 5:28 PM
Bigblock
Joined Feb 14, '09
From Mid West
korban, by now you've got it figuredout. I'm new to computers and imports,so you've had multiple ideas tossed at you.I would have thought it was engine management or anti-theft.Apparently no engine management since one person has removed theirs.Wiring scares the shiznit out of me.Best of luck.
post Feb 16, 2009 - 1:29 AM
korban
Joined Feb 5, '09
From New Zealand
QUOTE (Bigblock @ Feb 15, 2009 - 6:28 PM) *
Heh, nope, haven't figured it out yet. Wiring diagrams I've found seem to point to it being some sort of amp/crossover. It's definitely not engine management, as I've removed that (under the dash in the centre) and opened it up to see what's what (before wiring in an aftermarket system).
Could be central locking control, might just have to open it and see.
post Feb 16, 2009 - 1:57 AM
Rusty
Joined Nov 5, '07
From New Zealand
yup
post Feb 16, 2009 - 3:05 AM
korban
Joined Feb 5, '09
From New Zealand
QUOTE (Rusty @ Feb 16, 2009 - 2:57 AM) *
yup
Got a pinout? Might be fun to play with.
post Feb 16, 2009 - 3:50 AM
korban
Joined Feb 5, '09
From New Zealand
Well, i'm still just as confused.
The lack of caps suggests it's not an amp, the coils could be some kind of crossover? The space on the board says ANT, so maybe could be optional receiver for remote control locking?
Most likely at this stage it's... I have no idea. Next job to trace wires.
When I unplugged it my central locking still worked, and so did all my speakers. Anyone know if we have woofers hidden somewhere?
post Feb 16, 2009 - 1:38 PM
plug the part number into 1sttoyotparts.com
post Feb 16, 2009 - 1:45 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
its a receiver for something. you have a factory alarm or a factory key less entry?
post Mar 9, 2009 - 8:16 AM
ZGear
Joined Feb 16, '07
From BP, MN
Not sure if it's factory.....just recently found mine. lol
TRC: http://www.trc12volt.com/main-security.html
After some cleaning in my car I happen to have stumble across a module and a remote. Alarm system? Apparently the wire had been cut and the system removed for some unknown reasons. Here's a better look at the module and the remote.
There are many pins, I do remember when I was wiring my fogs that there was a loose harness behind my dash, but the other pins don't make any sense. Red pin indicates "LED", Blue is "VAl.SW.", White #1 says nothing, White #2 is "DOOR.L.", and White #3 is "SHOCK".
There's also a toggle switch number 1 & 2 "ON" and 3 & 4 "DIP"
Looks repairable, will try to see if I can hook it up.
This post has been edited by ZGear: Mar 9, 2009 - 8:21 AM
post Mar 11, 2009 - 4:11 AM
korban
Joined Feb 5, '09
From New Zealand
The DIP (Dual Inline Package) Switch is just 4 individual switches, the 'On' tells you which side they make a connection on.
It will either change settings, or change frequency that the remote works on (4 switches = 16 combinations) there could be a matching switch inside the remote.
Lo-Fi Version Time is now: September 1st, 2026 - 11:18 AM
