Feb 15, 2009 - 5:29 PM
Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) |
ALRIGHT! this will def. be a long time project for me but i will be done. so i have been lurking on mr2oc for a while and looking at dyno sheets and other peoples set ups and this is what i have come up with for MY build:
GOAL: 350hp daily driven and de tuned -stock 1995 5sfe block -gen 2 3sgte head with stock cams with gasket match and mild port and polish, valve job and rebuilt -possibly +1mm over sized valves -stock 3sgt3 rods OR if i can locate and ebay special on them eagle h-beams -will be using stock 5s crank machined to fit the 3s sized rods -all ARP hardware -HKS cam gears -CP pistons for stock bore (8.5:1) -850cc injectors -and the turbo that everyone seems to be running is the gt35 and 35r at that's the BASICS of the engine. the head work will start within the next week or so after i get it disassembled if you all have any concerns/ comments/ questions feel more than free to put in your 2cents...just keep the flames suppressed 460hp at 21psi on pump gas--stock 3rd gen cams http://www.mr2oc.com/showthread.php?t=317515 This post has been edited by b1gr3d: Feb 15, 2009 - 5:37 PM -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
b1gr3d 5sgte/ 3sgte stroker parts list*flame suit on* Feb 15, 2009 - 5:29 PM
baktasht * if you're using a 5sfe block try and stick w... Feb 16, 2009 - 7:18 AM
b1gr3d awesome response--
the only reason for the afterma... Feb 16, 2009 - 3:00 PM
baktasht Have a look at my other 2 threads regarding our 2 ... Feb 17, 2009 - 12:39 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 4:29 AM |
